Canada Serving Canada.
G35 Flip key
Old May 23, 2010 | 03:09 PM
  #31
netcbc's Avatar
lol how is it awesomer, it looks exactly the same as the OP posted
Old May 24, 2010 | 07:57 PM
  #32
Integi2a00's Avatar
got my flip key working today!
Old May 25, 2010 | 09:46 AM
  #33
elrooko's Avatar
Originally Posted by JOKER
Went from setup on the left to the setup on the right.
Yep - that is the same one I have...your awesomeness has been diminished...
Old May 25, 2010 | 10:28 AM
  #34
Steel Blue's Avatar
Thanks OP, I just bought one.
Old May 25, 2010 | 12:05 PM
  #35
netcbc's Avatar
Loving the flip key, just went rollerblading on the long weekend and all I needed was the flip key instead of bring a huge key ring of stuff....
Old May 25, 2010 | 12:14 PM
  #36
JOKER's Avatar
CLUB MODERATOR
it's awesome because it's mine
Old Jun 22, 2010 | 08:05 PM
  #37
Steel Blue's Avatar
I finally received my new key fob, and had time to put it all together, and I am extremely pleased with how easy it was.
The only issue I am having is that the key does not flip out very well when it hit the button. It will only flip out 1/3 of the way. Is this happening with anyone else or is this normal?
Not a deal breaker by any means I still very happy over all!!
Old Jun 22, 2010 | 09:31 PM
  #38
ScreaminG's Avatar
expecting mine in the mail this week...
Old Jun 22, 2010 | 09:47 PM
  #39
MTNBKR's Avatar
Have you tried winding the spring one extra turn to increase the force?
Old Jun 22, 2010 | 11:40 PM
  #40
Steel Blue's Avatar
I didn't even think of that. I will try that tomorrow, and post followup.
Old Jun 22, 2010 | 11:48 PM
  #41
cmthresher's Avatar
that will fix it. you can wind the spring so that it flips out better.. this is a real easy diy for anyone wanting this. i did it over a year ago. Lowe's cut the key for me for free.. and i popped the chip out.. i took a drop of super glue when i put it in the new key fob... i have had it work loose before and luckily i was home so i was able to take it apart and fix it..
Old Jun 23, 2010 | 11:21 AM
  #42
Steel Blue's Avatar
Thanks again guys for the tip on giving the spring more tension for the flip action.
Works great now!!!
Old Jun 23, 2010 | 01:31 PM
  #43
elrooko's Avatar
Yep - should have posted that - you need about 3 turns of the spring to make it snap back properly.
Old Jun 29, 2010 | 10:42 PM
  #44
ScreaminG's Avatar
the transponder and the little green housing for it dont fit in the designated spot...when i put the transponder in alone its actually loose...any solutions?
Old Jun 29, 2010 | 10:59 PM
  #45
elrooko's Avatar
Take the transponder out of the green housing - you don't need it. Just put the transponder chip only in the little slot and when you tighten up the case, it is totally secure.
