Canada Serving Canada.
G35 Flip key
Old Apr 21, 2013 | 08:59 PM
  #76
mynameisname's Avatar
Wouldn't you be able to just program the new flip key with your car since it comes with it's own transponder?
Old Apr 22, 2013 | 04:37 PM
  #77
netcbc's Avatar
I bought 2 flip keys from ebay, both eventually broke cause the screw couldn't hold everything together. Went back to stock unfortunately.
If anyone had a good experience with from a specific dealer, feel free to post. I know there's lots of different versions so maybe there's a superior one out there.
Old Apr 22, 2013 | 05:02 PM
  #78
Mine is pretty decent quality and not very expensive. I also left a detailed review on Amazon of how I did it. http://www.amazon.com/4Buttons-Remot...owViewpoints=1
Old Apr 23, 2013 | 03:19 PM
  #79
netcbc's Avatar
Does yours enclose fully? Mine had slight openings along the side....
Old Apr 23, 2013 | 03:22 PM
  #80
Mine has a small opening as well but that's because of the way I had to put in my remote board. It comes with 2 screws so you should be able to screw it shut without space on the sides.
Old May 15, 2013 | 02:23 PM
  #81
jewelz34's Avatar
I just bought one of these of ebay as well, removed the chip from my original key and placed into the new one. After closing it i can still here it moving around when the key fob is being moved. Does anyone know where exactly the chip is suppose to go or if im suppose to install it with the green housing that the chip was enclosed on the oem key?
Old May 16, 2013 | 10:19 AM
  #82
The transponder chip goes into the small half trapezoid shaped slot near the top of the key fob (right next to where the spring and metal key sit).
Old May 16, 2013 | 10:26 AM
  #83
This is the slot that I'm referring to.
Old May 16, 2013 | 10:59 AM
  #84
SergeantRed's Avatar
Flip Key
I have this one
Amazon.com: 4 Buttons Keyless Case For Nissan Altima Maxima 350z Infiniti G35 I35 Remote Flip Key No Chips Inside: Car Electronics Amazon.com: 4 Buttons Keyless Case For Nissan Altima Maxima 350z Infiniti G35 I35 Remote Flip Key No Chips Inside: Car Electronics
and it has NO gaps; the chip goes in the red box. I used sticky-tac to keep mine in place.
chinee
Jun 10, 2024 07:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
apintojr
Jul 23, 2015 10:52 AM
