Canada Serving Canada.
How Much Does...
Old Sep 13, 2005 | 06:56 PM
35bills's Avatar
How Much Does...
Hey Guys,
Does anyone know how much a replacement clock would cost the dealership?
I noticed that the bulbs behind my clock had gone out so I thought that I would be in line for a replacement. Wrong!!!
The dealer is going to order a couple of new bulbs instead. Service guy said that its too expensive for them to replace totally.
WTF???
Jerry, if you read this please give your 2cents.
Bill
Old Sep 13, 2005 | 07:52 PM
WolfsterX's Avatar
Tsb
Originally Posted by 35bills
Hey Guys,
WTF???
Bill
Here is the TSB: http://www.infinitihelp.com/Ownershi.../ITB03-065.htm
Sandip
Old Sep 13, 2005 | 08:58 PM
RBull's Avatar
Rated M
You beat me to it Sandip. I haven't changed any bulbs in mine but it sure seems dim. There must be two in there and maybe one is out.??
Old Sep 13, 2005 | 09:26 PM
35bills's Avatar
Thanks for the heads up on the bulb replacement TSB.
I'm just wondering how much the actual clock costs to replace?
Service guy said around $1000. I think he was yanking my chain( maybe not?).
Bill
Old Sep 14, 2005 | 01:56 AM
WolfsterX's Avatar
Hi Bill
Here is another TSB:
http://www.infinitihelp.com/Ownershi.../ITB02-079.htm
That is for Sedan but u can look at the picture that provided and it should be covered by warranty.
Sandip
Old Sep 14, 2005 | 09:43 AM
PDT's Avatar
PDT
I had the same issue where one of my bulbs burned out in the clock. Jerry ordered me a new clock and all covered under warranty. I figured he would have replaced the bulb(s), but he replaced the whole thing!
Take the TSB to your dealership and tell them to order you a new one.
Old Sep 14, 2005 | 01:31 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I've noticed the same thing Deane...
If the dash lights are dimmed, you can hardly see the clock at all.
Turn the dash lights up & the clock is lit, but much dimmer than the rest of the lights.
Old Sep 14, 2005 | 05:11 PM
Msedanman's Avatar
O.F. Administrator
Bill
Yah, that's sounds like a chain yank doesn't it......
Another factor for you Bill is that the newer clocks have thicker, more legible hands.
Tell them a new clock is doable elsewhere, but if they want the business, then that's what you want.
New bulbs, without the newer, wider hands isn't going to solve the issue.
G/L Hope to see you on the 18th at Sportworld.
C.
Old Sep 14, 2005 | 05:44 PM
RBull's Avatar
Rated M
Exact same as mine. I'll check it out with them in the next couple of weeks and let you know. What I really need looked at is my two chip spare keys do not work anymore. The engine will crank over but no fire. Good thing my regular use one works now and I find out by accident my spares are defunct.
Old Sep 14, 2005 | 10:19 PM
InTgr8r's Avatar
Sounds like they missed programming them.
They get flashed, so shouldn't loose the code,
Old Sep 15, 2005 | 09:06 PM
RBull's Avatar
Rated M
No they have been used before. It's the first time I have used them since the battery disconnect for the plenum.
I talked to Infiniti today and they could not recall the problem before but said the chip might be defective or that may be able to reprogram if I bring in the car and all the keys.
Old Sep 15, 2005 | 09:52 PM
InTgr8r's Avatar
hmmm that's a strange one.
Should have nothing to do with the battery being disconnected for an extended period.
I would tend to agree that it's a chip failure if only one, but two?
not likely.
Stubie1918
Accessories
Nov 2, 2013 06:09 PM
Beebo
Jan 23, 2012 02:06 PM
Rush808
West
Jan 12, 2012 06:58 PM
Dontjipme
Oct 16, 2010 01:54 PM
