Ask a Professional Detailer...
Rating: Thread Rating: 10 votes, 5.00 average.
Old Aug 6, 2007 | 04:36 PM
  #301
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by malukalu
Hey quick question here. Actually its for a friend that doesnt believe me!...well i could be wrong so anyways here goes:
How long does a "common" wax last? Does it last through normal washes? My impression was that a good was job can last atleast a month or so regardless of intermittent washes ( so wax once and wash 4 times afterwards with no wax re applied). Obviously if you use a harsh soap such as the Dawn stuff people mention here i would imagine it would strip the wax in one wash...but if you are using normal car wash liquid it should keep the wax in tact right?
Actually he gets his car washed by someone who comes to our office ( mobil detailer) and gets a wax every time... which brought about this question...
cheers
Prem
A wax will typically last anywhere from 2-8 weeks.......depending on your washing habits. I typically wax my G every 4 weeks or so and reapply my sealant about every 3 months.
Old Aug 6, 2007 | 04:39 PM
  #302
Originally Posted by RBull
That's what is on mine and my dad's Frontier. Looks and works great. By far the easiest LSP to work with I have ever even imagined. You can almost remove it by looking at it.
BTW, how did the liquid wax I gave you work?
George has told me that as well Deane that FMJ is so easy to use. I am all out of Zaino Z2 and Z5 and only have half of my EX-P left. I plan on trying FMJ next.
I just used that liquid wax for the first time on Saturday. I really liked it and it gave my G some really nice depth in appearance.
Old Aug 6, 2007 | 06:13 PM
  #303
RBull's Avatar
Rated M
Good stuff. You need to really shake it up well.
The guy I got it from said it's from California and lots of fire stations use it on their trucks. (Red )
Old Aug 6, 2007 | 10:27 PM
  #304
Detailed Image's Avatar
Originally Posted by JfromTheBay
Hi George im sure that this question has been asked before.....and apoligize for bringing it up again.....I have a black G35 and my largest problem is with water spots and bird ****...... i live in Rainy San Francisco and unfortunatly have to park outside a good amount of the time....what processes and products would best help me remove waterspots and keep me best protected from future waterspoting.....also i happen to live where there is a lot of bird traffic to and am sometimes am not able to remove bird **** quick enough so that when i look at where the **** used to be at an angle i see some hazing in the paint....what product and process would be best to help with this problem?
Thank you for your help and rest assured that Autogeek was erased from my favorites and was replaced with detailedimage.com
Garnet Canuck
offered some great advice. I personally keep a 4oz Pump Spray Bottle of Spray & Wipe in my glove box along with an ultra plush microfiber towel for emergency bird bombs or if you want to get rid of water spotting, etc.
The best thing you can do to protect your paint is to apply a quality sealant once a season, so 4x a year. Most synthetic sealants last anywhere from 3 - 6 months, so on a daily driver, factor in the lower side of the estimate. This gives you enduring protection year round. To maximize your protection, layer a quality wax on top of the sealant, which is only going to last 2 - 8 weeks, however, this seems to bead better (minimizing water spots) and also seems to prevent bird droppings from etching as quickly. It will also enhance the look of your paint, usually by adding more depth and gloss. I start off with 2 coats of wax spaced at least a day apart, and reapply at least once a month for maximum protection.
Thank you for the kind words and I apologize for the delayed reply. We are working hard on launching our new website, which is going to have a lot more features, more information, better how-to's and much more. My time on the forums has been cut short due to the time needed to complete the new website. Thank you for your patience and let me know if there's anything else I can answer for you.
cheers
Prem
Prem, you are right on track with what you said. The durability of the wax is very dependent on what shampoo, wash tools and techniques are used. A shampoo with strong cleaners, such as Dawn, can easily strip down wax. Quality automotive shampoos are filled with lubricants that lift dirt and grime from the surface, maximizing your coat of wax. Wash tools play a major factor in durability of a wax as well, if you dry your vehicle with say a water blade, not only should you expect some imperfections, but your coat of wax will be diminished much quicker due to the extra friction being applied to your clear coat. Your best bet as far as drying your vehicle is to blot dry with a quality waffle weave microfiber towel to minimize contact with the paint. Using a brush, bristled car wash, too strong of a pressure washer, and other improper wash tools will also diminish the durability of protection.
Typical waxes last 2 - 8 weeks, typical synthetic sealants last 3 - 6 months.
Garnet Canuck and RBull - thanks for chiming in with your thoughts, they are dead on
Thanks for being patient with me gang, new site is due out Mid-September. If anyone has any features, ideas, or anything else to make your experience with Detailed Image better, please let me know.
George
Old Aug 8, 2007 | 01:56 PM
  #305
malukalu's Avatar
Hey George, about to do some serious shopping on your site so i wanted to make sure i have the right setup. I have an 06 DG coupe and the paint is in pretty good shape. I can see some light swirl marks /scratchs starting to show ( probably me just being ****) . Actually i may go in on all the supplies with a friend who has a 06 Black IS350 who definitely needs some TLC in the swirl/light scratchs department.
Im pretty much a noob when it comes to detailing but im fairly handy so im hoping i should be ok..
how is this "kit" i put together?
Paint Prep Kit #6
http://www.detailedimage.com/store/p...roducts_id=432
Paint Protection Bundle #7
http://www.detailedimage.com/store/p...roducts_id=332
Porter Cable (PC) 7424 Advanced Kit
http://www.detailedimage.com/store/p...roducts_id=406
Wash Kit #7
http://www.detailedimage.com/store/p...roducts_id=395
(comes out to $350.78 shipped with George's G35 discount for those interested.)
Old Aug 9, 2007 | 10:00 AM
  #306
malukalu,
That package looks excellent for your needs. It gives you everything you would need to properly detail a vehicle with light to medium imperfections as well as seal and protect the paint. The products you selected are easy to work with and yield excellent results.
I think it's great that you found someone to go halves with to cut the cost down for each of you. To give you an idea on how long each product would last...
Super Slick & Suds ~ 60 washes (I use 1 cap full per wash)
Intensive Polish ~ 5 - 8 coats
Final Polish II ~ 5 - 8 coats
Finishing Touch Glaze ~ 5 - 8 coats
EX-P ~ 8 - 16 coats
Natty's ~ 15 - 25 coats
A few things to potentially make your package even better... consider an additional waffle weave drying towel, a Grit Guard Bucket Insert, and some quality microfiber towels for removal of products.
I'm excited to hear about your results, let me know if there is anything else I can answer to help you get the most out of your details.
Thanks for your support.
George
Old Aug 9, 2007 | 11:32 AM
  #307
malukalu's Avatar
Originally Posted by Detailed Image
malukalu,
EX-P ~ 8 - 16 coats
George
Thanks!! Now how often should i use the each of products? Obviously the wash and possibly the wax is what i will use the most...
Old Aug 9, 2007 | 11:37 AM
  #308
Washing - up to you really, but once every 2 weeks is a great starting point
Clay - 1 to 3 times a year, typically on your big details (Spring & Fall maybe)
Intensive Polish - As needed and only during your big details
Final Polish II - depends on how **** you are about your finish but definitely Spring & Fall, if you are real ****, once a season when you reapply your sealant
EX-P - once a season
Natty's - once a month
These are some suggestions, let me know if you have any other questions.
George
Old Aug 10, 2007 | 01:15 PM
  #309
remsleep1's Avatar
Thanks George for the great information on detailing. I had no idea how good you guys are and how technical detailing can be.
I will definitely be buying some stuff from your company.
Quick simple question: I just bought a 07 G35x 2 weeks ago and want to wash it for the first time. Do I need to do the prep, polish, glaze, sealant this early or would a proper wash and sealant be all I need for now?
Cheers
Old Aug 10, 2007 | 02:03 PM
  #310
The faster you can do the initial prep work, the better off you'll be. Claying a new vehicle is very important to remove embedded contamination that may have settled during transportation of a vehicle.
You certainly can just do a wash and sealant, however you will benefit quite a bit more from properly prepping your vehicle as soon as possible.
Thanks for your feedback, let me know if there's anything I can assist you with.
George
Old Aug 12, 2007 | 02:52 AM
  #311
luv2drv_myG35's Avatar
George,
The directions for PB's Wheel Sealant says wash, dry, and polish wheels first. For a new G35 (3 months) with factory rims, is polishing necessary? If so, what type of polish do you recommend?
Also, for doing an engine detail on an older car with PB's Degreaser, should it be used full strength or diluted?
Old Aug 12, 2007 | 03:33 AM
  #312
Cheers
Glad to see you'll be detailing your new G Mike. It's very gratifying I find having your vehicle properly detailed.
On a side note, I won't be able to play that round of golf with you as I blew out my knee this morning. Unfortunately, I am done for golf for the remainder of the season. Details here. I'd still like to get together for a meet though.
Old Aug 13, 2007 | 10:35 AM
  #313
Originally Posted by luv2drv_myG35
George,
Good questions.
Polishing is only necessary if the wheels have been neglected and have lost their finish and have lots of contamination built up on them. The solvents in PB's Wheel Sealant actually have some cleaning characteristics so it will clean up minor contamination, stains, etc. The more contamination you remove prior to starting with the Wheel Sealant, the more durable the coat will be, plus you will ensure complete coverage.
I always dilute the PB Bio-APC, usually 4:1 and work down if needed. For customers vehicles, I typically used 2:1 for engine details.
Let us know how you make out.
Garnet Canuck - Bummer on the knee, hope you recover quickly.
George
Old Aug 15, 2007 | 10:01 PM
  #314
malukalu's Avatar
Hey George just got my shipment. Cant WAIT to try this stuff out. First tiem using a PC
So i had a quick ( maybe not so quick ) question. I see that i have 4 pads ( 2 white, 1 orange and 1 black) and the following things to apply
1.Final Polish II
2.Intensive Polish
3.Finishing Touch Glaze
4.Poorboys EX-P
5.Nattys Paste Wax
Ill be saving #1 for a later detail but do have the pads right as follows?
2.Orange
3.Black
4.White
5.White
How long should these pads last? I assume one pad is enough for each application? Also what settings on the PC would you recommend for each stage? Sorry if you already answered these questions, if you can just point me to them im sure ill be fine..
cheers
Prem
Old Aug 15, 2007 | 10:20 PM
  #315
Infinite1's Avatar
20 Year Member
1.Final Polish II
2.Intensive Polish
4.Poorboys EX-P
5.Nattys Paste Wax
2.Orange
3.Black
4.White
5.White
cheers
Prem
Congrats on getting the your shipment! I know the same excitement you're going through. I just used my PC for the first time last weekend (Pics to come George!)
On to your question....Orange pads are used typically first to remove possible deep intermediate type swirls as they have more "cutting" abilities. The white pads are used more for light swirl removal and final polishing (i.e. #1 on your list). The next is the black or grey pad which is used to apply your sealant or glaze. And of course you can apply the Natty's by hand. I used the Natty's blue myself and I find that doing it by hand to apply a thin layer is better than with the PC.
Also, you can save one of those white pads for later use. You don't have to switch to a brand new one for the next panel. A tip I learned is to mist your pads with water so they're not dry when they come in contact with your paint and pick up a nail brush(go to the travel sized items section in wal-mart they're about 50 cents) to clean out the caked up residue before moving to the next panel.
Well I hope that answered your question a little. George please correct me if I missed anything. Thanks!
Ryan
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
