Optimum no rinse?
Old Oct 31, 2008 | 04:28 AM
accordfreak's Avatar
in between full details, i use it almost once every week or two. i have twilight blue so swirls are easy to see but this stuff hasn't shown to mess up my paint. 2 bucket method here. Also, with a little more product, it's slick enough for the clay bar for those full details.
Old Oct 31, 2008 | 07:22 PM
Asad_A203's Avatar
ONR is great; couple things which I keep mentioning is to use a Microfiber wash mitt as ONR washes will completely destroy a sheepskin mitt (tooo much dirt), and if vehicle is excessively dirty do a spray down with 2:1 concentration then followed by ONR wash. I only wash one panel at a time in winter when it is too cold (water will freeze) but for the most part I wash the car completely before I dry it. I apply a spray of Quick Detailer and then dry the vehicle with my Waffle Weave Towel.
ONR is some great stuff; clay lube, Quick Detailer, rinseless wash, APC... one of the better investments you will make with a detailing product.
Old Oct 31, 2008 | 07:43 PM
redlude97's Avatar
I use ONR with sheepskin mitts exclusively, and haven't noticed any accelerated degradation
Old Nov 1, 2008 | 01:36 AM
Mr. Samster's Avatar
i was wondering would it be okay to use clay bar after we use ONR?
Old Nov 2, 2008 | 01:12 AM
Asad_A203's Avatar
How often do you clean your wash mitt or rather what do you use to clean it with after ONR washes? I have found I need to include a cleaning of the wash mitt with liquid detergent (Woolite) after each ONR wash since the mitt is much more dirty than a regular wash would have the mitt. Regular wash cycles (outside with a rinse wash) I can get away with rinsing the mitt with the garden hose and then letting the mitt soak in a bucket of water overnight and 90% of the junk will be off of it.
Old Nov 2, 2008 | 01:16 AM
Asad_A203's Avatar
As long as you use a lubricant; it should be no issue. I would not clay while you are doing the wash though. Wash the vehicle with ONR, dry it (if necessary do an ISA wipedown if you have any sealant/wax on the vehicle) and then clay the vehicle. ONR is extremely slick and can also be used as a clay lube even at the 1:1 ratio but it is recommend @ 2:1.
Old Nov 5, 2008 | 10:49 AM
Cassman's Avatar
I agree. You can always clay a CLEAN car. ONR produces a CLEAN car.
Detailed Image
Sep 18, 2015 03:43 PM
bsgoren
Aug 20, 2004 12:56 PM
hyunwoo8521
Mar 20, 2004 01:33 PM
R1cky
Mar 16, 2004 01:11 PM
Snareman
Jun 2, 2003 10:42 PM
