Restoring Polished Exhaust Tips
Old 02-20-2009, 11:11 PM
Skaterbasist's Avatar
Retired SuperMod
What would any of you recommend for cleaning very dirty & stained exhaust tips?
My car does not have catalytic converters. I didn't bother cleaning the tips for months and now it almost seems impossible to get them cleaned. I have tried scrubbing down the inner walls of the tips with no avail
This is how they're SUPPOSED to look:
Old 02-20-2009, 11:15 PM
Calvin's Avatar
Overglorified Altima
https://g35driver.com/forums/care-de...cs-inside.html
I've used this on my exhaust tips as well. Seems to help, although the difference was not as drastic.
Old 02-20-2009, 11:30 PM
ShanesG's Avatar
Wash it let the soap soak a lil, then maybe a gunk/wd40, then some metal polish, if not some very high frit sand paper!!!
Old 02-21-2009, 12:04 AM
WhosRich's Avatar
try a lil #0000 steel wool and metal polish. should do the trick unless they are really dirty,
Old 02-21-2009, 08:58 AM
6']['9's Avatar
Mothers billet works very well.
Old 02-21-2009, 06:43 PM
superchargedg's Avatar
+1 as i have used this method and it works quite well.
Old 03-27-2009, 11:30 PM
Retired SuperMod
So I decided to give BlueMagic a try, and it worked like a charm!
Keep in mind that my exhaust doesn't have any catalytic converters and the exhaust was stained from months of not being cleaned.
This is what 5 minutes of soap/water + brush scrubing accomplished:
This is what 2 minutes of a quick cleaning did with the BlueMagic polish with nothing more than a rag:
I didn't finish it up since I was just trying out the product and it was already dark though
Old 03-28-2009, 07:47 PM
4DGS's Avatar
Start with 000 steel wool, clean it with soap and water, then wet sand with 3000 grit sand paper. Then polish with an aluminum polish or braso.
linedr89
Engine - Power Adders
10-04-2015 07:29 PM
cmesidewayz
09-29-2015 09:28 PM
Albanian122
09-12-2015 04:02 PM
Detailed Image
09-11-2015 08:37 AM
Red G Coupe
Video Share
09-06-2015 06:45 PM
Quick Reply: Restoring Polished Exhaust Tips
