Removing stickum
Old 01-29-2006, 08:34 PM
Goods's Avatar
Removing stickum
I got my car with the plastic wrap still on the exterior. What's the best way to remove the glue that holds the tape on? Is that a job for a claybar or something else?
Old 01-29-2006, 09:28 PM
HokieZ's Avatar
WD40 works well as does most bug/tar remover. I'd personally recommend the latter as it's been forumated to be safe with paint.
Old 01-29-2006, 11:22 PM
Gordgee's Avatar
Administrator
If your car was new, the dealership has a responsiblility to prep the car. Point it out to them, and for your inconvenience of bringing it back in, ask them for a freebie.
Old 01-29-2006, 11:42 PM
Andy2434's Avatar
+1 . . . Your car should have received a thorough prep and detail prior to you driving it off the lot.
Old 01-30-2006, 12:01 AM
Goods's Avatar
No, I asked them not to wash/wax it.
When I peeled off the plastic and washed the car I see that it left fine lines of sticky stuff just around the edges where the plastic was. It comes off if I rub it kind of hard with a microfiber towel, but I don't want to rub that hard.
Old 01-30-2006, 12:29 AM
Andy2434's Avatar
Use Stoner's Tarminator to remove the adhesive residue. It's paint and clear coat safe.
Old 01-30-2006, 01:13 PM
GTScott's Avatar
I think you were smart to not have them prep it.
I would suggest soaking the car with a diluted bug and tar remover (something like Poorboy's Bug Sqaush if my favorite) so that you can dissolve as much as possible without scrubbing. Note, this will remove any wax you may have on the car. After that, I would wash it and then clay bar the whole thing. You will then be ready for a final wash and application of your wax or sealant.
This is what i did with my 06 and found it to work very well. The trick is to try to dissolve the glue residue before doing anything else.
-GT
Old 01-31-2006, 08:59 PM
Goods's Avatar
Thanks for the suggestions. Hopefully Grand Auto or Pep boys will have some decent bug & tar remover.
Old 02-01-2006, 10:54 AM
CBRworm's Avatar
both of mine came with the sticky lines still there. I used Honda polish. It is a motorcycle cleaning spray that Honda sells, and it smells good too. It is an aerosol that is designed to be safe on bike paint (which is frequently as good or better finishes than cars) and able to remove grease and oil as well as road grime.
It worked great both times.
Did I mention it smells good too?
Old 02-01-2006, 12:34 PM
HokieZ's Avatar
-GT
Definitely smart. Mine apparently used a scotchbrite pad to apply the wax, and 8 grit sandpaper to take it off. Unfortunately they are 4 hours away so I just took the porter cable after it. All better now.
05-22-2022 09:26 AM
RemmyZero
V36 DIY
04-23-2018 11:13 AM
Video Share
01-31-2017 04:00 PM
Extreme Dimensions
Southern California
10-19-2015 06:28 PM
dcsbh1
10-01-2015 03:15 PM
Quick Reply: Removing stickum
