[DFW] What have you done to your G Today?
Old Jul 15, 2011 | 12:53 PM
  #8101
LordFappington's Avatar
oh no i have like 7k worth of stuff to buy still, i hope to have the motor ready and sikky kit by september, then tranny bought by january electronics and everything else by march, I hope to have it wrapped up around June.
Old Jul 15, 2011 | 01:03 PM
  #8102
almost3flips's Avatar
Damn almost a year!
Old Jul 15, 2011 | 01:15 PM
  #8103
yeah
Old Jul 15, 2011 | 01:37 PM
  #8104
ezpotato's Avatar
jesus christ dude, you even gonna keep the car that long? haha
Old Jul 15, 2011 | 01:42 PM
  #8105
Ive done so much to it that changed everything such as widebody and having my roll cage welded in that im going to keep it forever.
Theres no turning back.
Old Jul 15, 2011 | 01:43 PM
  #8106
sexyrob's Avatar
jack, I don't think it's a good Idea to start building until you have all the parts. you don't want to damage any of those new bearings by accident. I think its typical that engine builders gather everything first, test fit every piece, do a pre build, torque everything to spec and measure clearances, take it all apart, clean everything, then do the final build in a day in a controlled environment to keep out particles. Generally you want to do the final build as fast as you can because you lubricate pieces and if it sits to long the lube wears out and you need that in place for the break in period.
I'm sure you already knew this.. but if you need any help, I found a really good video on engine building that explained a lot of things for me.
Old Jul 15, 2011 | 01:56 PM
  #8107
gmotion04's Avatar
jack how much is your cage running you? and who is doing it?
Old Jul 15, 2011 | 02:00 PM
  #8108
The Fapsmith's Avatar
So last night I decided I wanted to actually get my hands dirty and make use of the hair on my chest and do my suspension stuff with the help of CB..
First things first we go to take off a front wheel and WHAT DO YOU KNOW.... Three cross threaded lugs lol.. I figured they would be just because of how bad my luck is.
So we couldn't do the front bushings but we did do the rear camber kit.. It was fun, got greese all over me including in places where grease shouldn't have gotten but hey!! It was a good time...
Gotta buy some new studs on monday and we will finally do the bushings.
Old Jul 15, 2011 | 02:06 PM
  #8109
Thanks for your concern Rob, I only did the cam bearings because those are usually out of the way, I bought tons of assembly lube and I am also picking up some SAE 30 oil to keep everything nice and moisture free and then bagging when Im done.
Anyways these cam bearings are so particular the way they are installed Im pretty sure I got them in there perfectly. They were put in symmetrically and the oil galleys matched up pretty much on point... Not bragging or anything :P
Old Jul 15, 2011 | 02:19 PM
  #8110
Btw thanks for your help and input yesterday Rob
Old Jul 15, 2011 | 02:21 PM
  #8111
sexyrob's Avatar
oh wow, thats good... yeah I guess I'm just a bit overly cautious about some things. probably the reason it takes me forever to get anything done. plus I have no Idea about the LS, just know what I've seen with the VQ35DE
Old Jul 15, 2011 | 02:22 PM
  #8112
sexyrob's Avatar
no prob, almost positive your buddy fried some rings on the side that the cat was clogged, you can't drive hard when you have a problem like that.
let me know how the compression check turns out.
Old Jul 15, 2011 | 02:29 PM
  #8113
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
^rob.. a birdie told me something.. LULZ and woooooooooooooooow!! you know what im talking about
Old Jul 15, 2011 | 02:34 PM
  #8114
Yeah nothing should be touching the cam shaft bearings until I actually put the cams in, I'll have to show the process, this book is awesome, I was also reading a rebuild with a bare block on gm high tech performance. Theres so much available information that instills more confidence than building a vq.
Old Jul 15, 2011 | 02:50 PM
  #8115
sexyrob's Avatar
yeah... I can't wait to put your pipe in my engine, if you know what I mean. ;-)
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
