DFW Lounge (NSFW)
Old Jul 10, 2011 | 05:42 AM
  #2281
BIGP_G35DRIVER's Avatar
Depending on what you do in the military will dictate what kind of money you make and how many marines/soldiers/airmen or seamen you are in charge of. However being that i'm currently over in Afghanistan as we speak I'm in charge of 22 Marines and know them by first last and last name including where they are from and if they plan on staying in or getting out. Being a leader of Marines is what you make of it and how well you do is up to you. I knew that when I came into the Marine Corps that I was not going to stay in and was doing this for a stepping stone. 4 years of your life is nothing when you look at the big picture and student loans
Old Jul 11, 2011 | 12:16 PM
  #2282
vietboi817's Avatar
My left side headlight is out... Bulb is fine, and so is the fuse. I'm speculating that the ballast is out, is there a way to test the ballast? and if it is the ballast, where can I get a hold of one fast/cheap? I called Grubbs, 409$ for just the ballast.. wtf? I have an 04 Coupe upgraded to 06 projectors. Inputs please, thank you.
Old Jul 11, 2011 | 12:19 PM
  #2283
g35man04's Avatar
CLUB MODERATOR
ebay honestly for a single ballast
Old Jul 11, 2011 | 12:20 PM
  #2284
r1forever80's Avatar
Swap bulbs to check if its ballast. U can also get a testlight to see if ur getting power to ballast. I have an extra ballast. They are usually on cl for sale
Old Jul 11, 2011 | 12:23 PM
  #2285
sexyrob's Avatar
hey steven and chris.. turbos done yet? if not, don't post until they are.
Old Jul 11, 2011 | 12:25 PM
  #2286
Ouch. Such hostility
Old Jul 11, 2011 | 12:32 PM
  #2287
vietboi817's Avatar
Thanks Gs... Can I haz the ballast R1 ^^
Old Jul 11, 2011 | 12:35 PM
  #2288
U can has it for 50bucks. Usually they are on cl for 75
Old Jul 11, 2011 | 12:36 PM
  #2289
sexyrob's Avatar
I just want the best for you
Old Jul 11, 2011 | 12:51 PM
  #2290
g35man04's Avatar
CLUB MODERATOR
mine should be wednesday...start up most likely to bleed coolant lines and make sure everything is running without leaking.....
Have to modify exhaust tonight and make the markings to where I need to add in the vband clamp to bolt up to MD setup.
Add in all the fluids tonight as well. Finish last minute items such as making sure all bolts are tighened down. Install gauges tonight since all wires are ran!!
Old Jul 11, 2011 | 03:14 PM
  #2291
Th3R3dStar323's Avatar
cant wait for me to be doing all of that! i should be getting everything by the end of this week hopefully!
Old Jul 11, 2011 | 03:34 PM
  #2292
ezpotato's Avatar
so much boost in dfw soon
Old Jul 11, 2011 | 03:35 PM
  #2293
sexyrob's Avatar
I'm going to setup a tube that goes to my intake and blow into it for boost.
Old Jul 11, 2011 | 03:37 PM
  #2294
LordFappington's Avatar
I got one for my ***
Old Jul 11, 2011 | 03:42 PM
  #2295
hells yes i cant wait to get everything on!
im stationed in new mexico so im in the dfw when im back home on leave or a long weekend as im about 7 hours away.
once my kit comes in i will be driving the accord for a bit but thats why i got it for when the g is down!
