Drag NHRA, IDRC, IHRA, NDRA
Post up your 1/4 mile times
Old Jan 23, 2005 | 04:32 PM
  #31
Canton_G35's Avatar
My best stock was 14.27 @101.3 350ft. asl and conditions were great. low humidity and about 70. That was the same day RugRat got his 13.86.
Since then I've added some power and slicks so I'm hoping for mid 13s, this year. Getting low 13s would be amazing!
Someones gotta keep pushing Rugs to go faster.
Old Jan 24, 2005 | 12:08 PM
  #32
Juice79's Avatar
Originally Posted by F23A4
Seems like I need to get to THAT track.
That Maxima is mine. And THAT track was Englishtown...which I noticed from your sig is the same one you run at!!!
Old Jan 25, 2005 | 11:58 AM
  #33
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
How do you like the Tilton full-street flywheel & clutch? Hopw much was it including install?
Old Jan 25, 2005 | 08:05 PM
  #34
GodZilla's Avatar
Adding Timeslip Database Tonight when the site gets slow..
Old Jan 26, 2005 | 11:39 PM
  #35
DiamondGCoupe's Avatar
04.5 coupe 5AT MMode 14.656 @98.19. I ran my car for the first time tonight, a little disappointed on the outcome. i ran a 14.8, 14.7 and the 14.6. I have a Z-Tube, JWT POP Charger, 93 Pump gas, stock 18"s. I don't get why it wasn't around a 14.2-4. My 60' was a 2.36
Old Jan 27, 2005 | 01:01 AM
  #36
98intrigue's Avatar
its all about the 60' times. 2.3s suck. dont feel bad. i ran my car for the first time last week and with 5 runs, i had a 2.24 and the rest were high 2.3s. just work on the launch. did you torque brake?
Old Jan 27, 2005 | 11:21 AM
  #37
a.k.a. RANDYS_G
elevation of track? Ambient temp? Were you spinning the tires? MM or AT mode?
Old Jan 27, 2005 | 04:22 PM
  #38
court's Avatar
My G sedan auto in MM with INjen CAI helix race pipes and Borla exhaust ran a 14.9@95mph. this was at LACR where the track and track conditions suck.
the alt. is above 2500 ft. temp was 75-80
  #39
ChicagoX's Avatar
Don't drink and Mag Race
G35X-Stock
Best run so far: 14.50 @ almost 96 mph.
Best MPH: 96.13
670 ft elevation, mid-50's, unknown Baro.
Other runs same day: 14.52 , 14.54
File Type: psd
Old Jan 27, 2005 | 04:37 PM
  #40
a.k.a. RANDYS_G
Altitude Correction
LACR is 2,710 ft. above sea level.
To figure the altitude factor the formula is as follows:
ET: multiply your et (at LACR) by .97
MPH: multiply your mph (at LACR) by 1.03
This will give you the ET & MPH at sea level.
So, by these corrections, you ran a 14.45 at 97.8 mph.
Old Jan 27, 2005 | 04:41 PM
  #41
tluv's Avatar
03' Coupe w/auto 13.5 @107.mph at Ca. Speedway in Fontana. No traction what so ever. could have hit 12's easily with slicks.
Old Jan 27, 2005 | 05:07 PM
  #42
a.k.a. RANDYS_G
Terry, are you going to the next event they have there in March with Alternative Racing? I'm going to try, if I'm still here.
-Randy
P.S. Where you planning on telling these folks that you did that time with a 100 shot of NOS?
Old Jan 27, 2005 | 06:05 PM
  #43
My back tires are about done, so with VDC off my tires would spin out. I really babied it off the line, plan on renting slicks for tommorow night. I did get a better time each time i ran so i feel another night with 3-4 more runs, I should get things down better and be able to post some lower times, hopefully!! Otherwise, MOD CITY, here I come!
Old Jan 30, 2005 | 02:50 AM
  #44
SirMichael's Avatar
2.01
5.82
8.99 @ 79mph
11.52
Ford Probe GT
Swapped KLZE
Drag Radials
I/H/E
ALL MOTOR
Timeslip
Old Jan 30, 2005 | 02:36 PM
  #45
MyG35c's Avatar
60'- 2.244
1/4- 14.604
MPH- 98mph
5at in MM mode
This is my best time. Got this back in October. Weather wasn't great--40 degrees at night = no traction. I got this without torque braking, just mashing the pedal. Hopefully this spring, when the weather is better, i'll be able to actually launch the car and hit low 14's.
