Trans. ?
Old Jun 17, 2006 | 10:34 PM
H-townG35's Avatar
Trans. ?
Bought the wife a new 06 G35 sedan. While driving back home from a trip it seemed to me that the car was not shifting into 5th. I was crusing at about 75-78 mph and running close to 3000 rpm's. Does anyone know if this is normal for this car?
Old Jun 18, 2006 | 11:49 AM
dannyboi2088's Avatar
its normal
Old Jun 18, 2006 | 12:18 PM
sliderg35's Avatar
What was displayed in the gear display window? If it said "5". it was in 5th. When the trans doesn't shift for one reason or another, the display doesn't change either.
Old Jun 18, 2006 | 03:28 PM
w0ady's Avatar
fgc moderator
5th gear kicks in at about 120mph if i remember correctly.
Old Jun 18, 2006 | 10:02 PM
H-townG35's Avatar
Thanks fro the replys.
Old Jun 20, 2006 | 10:16 AM
rcdash's Avatar
120 mph? Ha ha.
5th kicks in at about 40 mph! The tranny will shift up right away in D mode.
(H-townG35, I assume you're talking about the auto).
Going about 80 at 3000 rpm sounds about right for 5th gear. You can always put it into MM mode and actually see what gear / rpm ratio correlation is.
Keep in mind that when you shift into MM, the car auto-downshifts - so it will at most show "4", until you manually up shift.
hellye1
Oct 6, 2008 12:00 AM
617G
Drivetrain
41
Apr 7, 2008 05:17 PM
moose1963
Feb 14, 2007 04:22 PM
xkoraznboix
Aug 19, 2004 01:34 PM
g35funk
Jan 3, 2004 06:26 PM
