Clutch Improvement Idea
Old Aug 18, 2006 | 11:08 PM
Leef's Avatar
Seems to me that the reason it's a bit difficult to take off and shift in the lower gears smoothly is that the takeup range -- the engagement range -- of the clutch is too short, giving an abrupt engagement.
And it seems to me that a possibly easy solution would be to fit a smaller diameter master cylinder or a larger diameter slave cylinder. This would give a longer takeup range.
Any thoughts?
Old Aug 19, 2006 | 12:21 AM
GEE PASTA's Avatar
Florida G35 Club
Any thoughts?
The clutch peddle is way to long, I understand what you are saying.
In drag racing, this is a major problem. My thinking would be 3 inches max movement. I working on this problem as we speak. And you here all the guys here over driving there engines on the strip. Great post!!
A direct linkage would be the only fix.
Old Aug 19, 2006 | 01:01 AM
Leef's Avatar
Why direct linkage? With hydraulic, by fiddling with the cyl ratios, you can get as much or as little engagement range as you want.
EasySausage
Sep 24, 2015 01:06 PM
yosip1115
Sep 9, 2015 03:30 PM
Rhinos7777
Sep 6, 2015 05:36 PM
TheBay
Sep 3, 2015 03:27 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
