Short Shifter Help
Old Dec 2, 2006 | 11:31 PM
Dakkerz's Avatar
Short Shifter Help
I installed a Nismo short shifter today and ran into a problem. Everything bolted up fine, but when I put it in gear the shifter moves around as if it's still in neutral! At first I thought I broke something but when I reinstalled the orginal shifter all was good again. Anyone have any ideas on what I did wrong or advice on what to do to resolve this issue. TIA all.
Old Dec 5, 2006 | 07:37 PM
Dakkerz's Avatar
anyone?
Old Dec 7, 2006 | 12:07 AM
GreenGoblin's Avatar
The goblin resurrection
not sure do you have to switch the bushing from the stock one to the nismo
Old Dec 13, 2006 | 02:37 PM
Dakkerz's Avatar
Which bushing are you talking about?
Old Dec 13, 2006 | 08:45 PM
http://www.rogueengineering.com/pdf/...er_install.pdf
I know this is not the nismo but should be almost the same
Old Dec 13, 2006 | 09:21 PM
Dakkerz's Avatar
Yeah those were the instructions I followed for the install. I did everything exactly how it was written up.
Old Dec 13, 2006 | 09:51 PM
eemon10's Avatar
how is the nismo short shifter??
Old Dec 14, 2006 | 03:02 PM
huh try measuring the stock on compared to the nismo and see if the bottom where the bolt goes through is the same
Dakkerz's Avatar
Haha, well if I can get it to work without being so loose I'll let you know. As far as I can tell though from the very short time I had it in the throws are a LOT shorter.
Old Dec 14, 2006 | 03:04 PM
Dakkerz's Avatar
Yeah I checked it to make sure. Since the height is adjustable I thought this might be the reason why it was off, but even when I made the shifter the exact same length as the stock one it still was loose (this was the third time I re-installed it)
Old Dec 14, 2006 | 03:12 PM
Hi-TechG35's Avatar
I believe that is normal. You will have the car in gear and the shifter still moves a little bit right? My RE does the same thing.
Old Dec 14, 2006 | 03:33 PM
Dakkerz's Avatar
Well a "little bit" i could live with, but it was no different than having it in neutral. It had the same amount of play regardless of whether it was in gear or not.
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
