Clutch gone bad! Need desperate advice!
Old May 20, 2007 | 07:11 AM
yoguh's Avatar
Hi all, I just purchased an 04 black 6mt coupe about 3 months ago at 19k miles. Being the new stick shift driver along with newbie roommates, my car is in desperate need to change the clutch already after about 2.5k miles of very heavy learning (quite a horrible mistake to learn and let my roommate learn on my first car I must say), but I have to deal with the situation at hand now.
I experienced massive slipping on my way back from Chicago so I'm really quite lost as to what it is I should do as of now. I've been reading up on this forum, but the posts are listed quite a while back, so I was hoping you guys would have some advice as to which brand I should get if I am looking for an after market clutch kit such as the ACT and JWT. I'm not really looking at modifying my car too much so anything that is recommended for decency and durability would be appreciated. It would also nice if you guys could shed some light on clutch+flywheel combos in my situation. Is there a need to get the combo, just for the sake of having the components work better with each other?
Old May 20, 2007 | 01:42 PM
trey.hutcheson's Avatar
I say go with the JWT combo. It's pretty cheap. I'm running the JWT flywheel, but a clutchmasters clutch.
Old May 20, 2007 | 05:42 PM
civic4982's Avatar
any gain seen from catching better will have some cost in how easy it is to drive.
you may consider just going back to OE nissan equipment if you're not planning to drive it that hard. personally I've felt that the OE clutch is fairly effective under spirited driving.
Old May 22, 2007 | 03:02 PM
Jeff92se's Avatar
Red Card Crew
decent advice there.
Joshua615
Aug 31, 2015 12:29 AM
zcherub
Aug 27, 2015 09:47 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
iknowitsfast
Aug 12, 2015 02:08 AM
