Replace Clutch G35 Clutch for $2500?!
Old Jun 2, 2007 | 05:38 PM
Ropate's Avatar
Replace ('04) G35 Clutch for $2500?!
Need advice please. I purchased an '04 Coupe @ 22 k here in Honolulu and just noticed the clutch slipping at 27k. OK, so the guy I bought it from trashed it. Can't do much about that now. However my Hawaii dealer says the warranty won't cover it and it will cost $2500 to replace. Is this the typical dealer schtick? I'm going to take it to my own mechanic who is competent. Do I use after market parts? Does it make that much of a difference. How much should this really cost to replace? mahalo!
Old Jun 2, 2007 | 05:55 PM
cipriopt's Avatar
It should be parts + 4-500$ for the labor. I suggest you get afthermarket, because there's plenty to choose from. And if you go afthermarket, you should get a flywheel too.
Old Jun 2, 2007 | 06:23 PM
Ropate's Avatar
Mahalo nui loa (Thanks very much) Cipriot!
Old Jun 3, 2007 | 01:44 AM
CFar's Avatar
Why is it out of warranty? Id call their bluff.
Old Jun 3, 2007 | 02:23 AM
jonnylaw's Avatar
clutch is only good for 1 year/12k miles--it's a wear item like the brake pads.
Old Jun 3, 2007 | 02:50 AM
ttrank's Avatar
Grocery getter
The problem is that they want to replace your flywheel at the same time. The oem one is a dual-mass unit and can't be resurfaced. They charge ~$1100 just for that part at the dealer. Go with an aftermarket 1pc flywheel and clutch to save yourself a ton. You will have a little clutch chatter but it will rev faster and reduce the rotational mass = more power.
I went through this when the dealer replaced my tranny a year ago. I was able to talk them into doing the clutch and flywheel install for me at the same time.
Old Jun 3, 2007 | 03:03 AM
jonnylaw's Avatar
^^+1
Old Jun 3, 2007 | 03:53 AM
Ropate's Avatar
Mahalo Jonny and ttrank...I've looked at some of the other clutch postings and it seems you can pick up a pretty good aftermarket clutch/flywheel unit between $500-750 so if I add the five bills for labor I should be able to get it done for a reasonable amount...
Old Jun 3, 2007 | 04:00 AM
hai109's Avatar
Aftermarket is a lot better then stock...When you choose a pressure plate don't choose something too aggressive or you won't like the engagement of the clutch. You won't have a nice smooth start...Those clutch require and nice quick launch...You would want to get a nice street version so the engagement is not too harsh for everyday driving...
Old Jun 3, 2007 | 04:18 AM
Ropate's Avatar
Sounds good hai109...got any particular products in mind? I'm not a street racer. Strictly up and down the hill and creeping along the freeways over here (max speed limit officially 55 mph)!
Old Jun 5, 2007 | 08:21 AM
Q45tech's Avatar
Aftermarkets are much noiser so be prepared............maintaining oem as new noise and vibration levels requires oem parts.
Old Jun 5, 2007 | 05:09 PM
Ropate's Avatar
Thanks Q45...noise is an issue but would it be a factor when the clutch is not engaged? I don't quite get it.
Old Jun 5, 2007 | 05:45 PM
jonnylaw's Avatar
Relpacing the clutch/flywheel combination on these cars, does come at a cost. For me, it is worth it, but if noise is a major concern, I would not stray from the OEM--but stock is so expensive, I just couldn't help but spend the same amount for a much better setup.
Sometimes it's quiet, sometimes I get some pretty weird noised from the pressure plate, and of course the "cement mix" noise at idle/low rpms from the lightened flywheel.
When you engage the clutch, the noise goes away--I wish I was smarter, but I dunno why this is--maybe someone else can chime in on the actual dynamics involved.
You definetly lose a little refinement when going aftermarket, but you gain a setup that is more durable and "funner" to drive--but that's just me an mo, as I don't mind turning up the stereo if my windows are open.
BTW, I can barely hear any chatter at idle w/ the windows up, but I can hear/feel the "rumble" from 1800-2000 rpm or so, but I learned to adapt my driving style to minimize it.
It's really a trade-off. Ask yourself what you want to do with the car and if you have later plans to mod it more in the future. Hope that helps.
Old Jun 5, 2007 | 06:00 PM
Ropate's Avatar
Jonny...that's very helpful. I think a decent aftermarket setup is the ticket. mahalo nui loa
Old Jun 5, 2007 | 06:15 PM
jonnylaw's Avatar
no problemo--let us kno how it all turns out for you
rezendvous420
May 31, 2020 01:26 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
