carbon fiber driveshaft???
Old Sep 13, 2012 | 01:23 AM
  #481
gabe3d's Avatar
^That would be my guess as well since he did say that he source these locally to socal.
Old Sep 13, 2012 | 10:36 AM
  #482
herrschaft's Avatar
I'll call GTM today to verify but I'm pretty sure thats where they're sourcing mine.
Old Sep 14, 2012 | 02:15 PM
  #483
Row2k's Avatar
20 Year Member
G35 Coupe
Haven't popped in this thread in a while, but I'll chime in. Its now been about 6 months since I've installed my Powertrain Industries CF shaft and still no issues. I was just under the car this past weekend changing out exhaust gaskets and everything is still spot on with the shaft. I've also done a track day since installing the shaft without any problems.
Old Sep 14, 2012 | 03:02 PM
  #484
bluedevils95's Avatar
Just waiting on z1 motorsport to make more
Old Sep 18, 2012 | 04:19 PM
  #485
G&Z's Avatar
G&Z
I just received a message from z1 and they are claiming the driveshafts will be availabe again in 1 month. I will be getting one the second they are in and im gonna have it installed and before/after dynoed at stillen. Ill post again with results
Old Sep 18, 2012 | 08:10 PM
  #486
herrschaft's Avatar
Found out GTM is sourcing theirs from Inland Empire Driveshaft here in Socal. Never heard of them before but their aluminum shafts run for around $500. I'll put it to the test when I eventually get the car back.
Old Sep 18, 2012 | 08:39 PM
  #487
3truman's Avatar
Glad to hear because i am looking forward to getting one, my bday is in November......
Old Sep 18, 2012 | 10:02 PM
  #488
JuicinJake's Avatar
ive heard a RUMOR that z1 is also looking into releasing a line of carbon fiber driveshafts too... which i suspect will hit right after the aluminum ones. has anyone else heard this? ( i heard this from someone that worked at z1 btw )
Old Sep 23, 2012 | 09:38 PM
  #489
Silencer_0's Avatar
These guys? http://www.iedls.com/
They're about 15 minutes away from me, lol. Maybe I should pay them a visit.
Old Sep 23, 2012 | 09:51 PM
  #490
unvmyg's Avatar
If you do let me know if they will make a CF. thx
Old Sep 23, 2012 | 11:53 PM
  #491
herrschaft's Avatar
Looks like them. I won't be able to give a review for about another month though.
Old Sep 24, 2012 | 04:12 PM
  #492
G ZILLA's Avatar
Thumbs up
Originally Posted by chiapet15
Any new updates G Zilla?
Sorry all Ive been moving and working 120/hr a week! yes per week!
so basically I am running 6psi less boost and make 12hp less than the steel DS set up.
Car is pretty much identical. I do have long tubes on now vs strup and test pipes but I cant see that being too much diff. It does provide a 1psi drop in boost from what i have been told.
car made 545.4/445 at 19psi w the CF DS vs the 557/460 at 25psi with the stock DS
I will try to get a straight same day comparison. I want to know for myself. but bare with me my life is a trip, this is the first time i logged in, in a minute besides replies to PMs on my phone.
UPDATE THREAD
https://g35driver.com/forums/nationa...te-thread.html
Old Sep 24, 2012 | 04:15 PM
  #493
G ZILLA's Avatar
Thumbs up
Originally Posted by Dsskyline
I say average for me anyway 8-12hp. Has the same effect as putting on light weight wheels or anything that reduces rotational weight.
What is the critical speed and rpm of the AL shaft. Here is a chart I found on critical speeds.
http://www.pstds.com/driveshaft_crit...peed_chart.htm
Probably a speed most will never reach, but the RPM some can reach if it's in the mid-upper 7k range depending on how long the shaft is. The 5at shaft is a little shorter than the 6mt.
I've taken mine to 130mph, 7300rpm and over 50 dyno and track runs no issues so far.
another reason CF is FTMFW! LOL im spinning 7500rpms currently
Old Sep 24, 2012 | 06:36 PM
  #494
Sylvan lake V35's Avatar
I am 7,500 with an aluminum one, mine is custom built and beefed up a lot...I am not sure if the mass produced ones just run OEM yokes and joints? I haven't had any issues at all with mine. I have never measured the OD but I think it's 4.5".
Old Sep 26, 2012 | 06:29 AM
  #495
G ZILLA's Avatar
Thumbs up
yeah thats a great question man. My yokes "appear" to be beefed up on the CF too. I wonder if we can find out about the mass produced aluminum ones? ANYONE?@!?@??@.
Although most aren't running such high RPMs, the few that are, this could be a big a deal if vibration is present.
