Shifting between gears feels harder?
Old Aug 21, 2008 | 02:20 AM
Deepdiver's Avatar
Originally Posted by speedracer04
One more question, is that something that a dealer could look up (assuming it would have been done at a infiniti dealer?)
thanks!
it is my experience that they have their databases linked.
Old Aug 21, 2008 | 09:07 AM
speedracer04's Avatar
thanks, the dealer said it did not come up so i guess i will take it in just to make sure and so it is in there database in case something happens.
Old Aug 21, 2008 | 11:40 AM
true's Avatar
Infiniti says 30K. A lot of enthusiast forum members change more frequently.
Correct me if I am wrong, but MT's do not use transmission fluid, they use motor oil. I just wanted to make sure people don't waste their money.
Old Aug 21, 2008 | 12:23 PM
Deepdiver's Avatar
That is incorrect, motor oil is not used.
Old Aug 21, 2008 | 03:19 PM
true's Avatar
OK, I'll bite. What fluid is used?
Old Aug 21, 2008 | 03:27 PM
true's Avatar
I checked it out. 75w85 HQ "manual transmission fluid" aka motor oil.
Old Aug 21, 2008 | 05:37 PM
Deepdiver's Avatar
are you sure you're not talking about gear oil? Motor oil has much lower viscosities (10w40, 5w30, etc.). Again, I would not put motor oil in my transmission.
Old Aug 22, 2008 | 10:44 AM
true's Avatar
Not necessarily true. You can usually find motor oil in very heavy weights and viscosities. For example, in my 93 and 97 honda accords (I supercharged both of them) the manual trans was filled with a heavy weight motor oil. Where oil goes from "motor" to "gear" is arguable, but I understand what you are saying.
Old Oct 10, 2008 | 09:13 PM
mreh's Avatar
An update for those who had similar issues:
I took the car to the dealer and they noted it was not normal and the car was grinding 2nd gear.. they are replacing the entire tranny in the car under warranty
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Paragham
Sep 15, 2015 12:04 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
INVADER_6MT
Sep 3, 2015 01:47 AM
