Please help with clutch question
Old Aug 22, 2008 | 11:21 PM
saeshaun007's Avatar
so i went to the infiniti dealership because i was having a problem shifting into second gear and sometimes 4th. it was also making a grinding sound when releasing the clutch. Infiniti is replacing my transmission under warranty and suggested i replace my clutch as well. so this is where i need the help. i want to go with the nismo clutch setup and i know i need the:
1. Nismo clutch Plate
2. Nismo clutch disc
Infiniti also told me i need a throttle bearing and i guess i need a pilot bearing?
Infiniti is trying to charge me a arm and a leg for the nismo clutch disc...$500 just for this disc which i know is way overpriced so my question is what do i need and where should i buy it. Please help....Thanks
Old Aug 22, 2008 | 11:23 PM
sorry i have a 06 g35 DG coupe 6MT
Old Aug 22, 2008 | 11:25 PM
eljoker's Avatar
If its under warr.. then the stock clutch is gonna be your best bet unless you wanna pay for the nismo but if the labor is free then just look around and see if you can get it else where but $500 for nismo sounds right
Old Aug 22, 2008 | 11:33 PM
the labor is going to be free but the clutch in not covered under warranty so i have to buy one anyways. but i want a better clutch because i going to eventually go with a FI setup most likely the vortec SC.
Old Aug 22, 2008 | 11:54 PM
eljoker's Avatar
check the market place i think you can go with JWT for a whole lot cheaper than the NISMO
Old Aug 22, 2008 | 11:57 PM
i hear too many problems with the jwt clutch. grinding noise? kinda turns me away from the jwt
Old Aug 23, 2008 | 12:03 AM
eljoker's Avatar
i thought that the noises came from the flywheels not the clutch but yea check the marketplace you should be able to find sumthing cheap and reliable
Old Aug 23, 2008 | 01:22 PM
ok so i still have not really gotten the answers i am looking for.
where do i buy the nismo clutch set up? and what all do i need?
or should i just go with the jwt set up?
anyone with the jwt clutch and disc?
Old Aug 24, 2008 | 05:45 PM
Diesel Dan's Avatar
You need a pressure plate, clutch disc, release bearing and a pilot bearing. I think I saw the nismo clutches on everythingg35.com
jsimonk
Dec 22, 2023 03:49 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
socalg35x
Jul 28, 2015 10:42 AM
