Transmission Problem..HELP
Old Nov 26, 2008 | 01:02 PM
g35freak86's Avatar
03 5AT sedan with 59k
Ok so i was on the highway today going to class driving normal, nothing crazy or pushing the limits. Then I put it into 5th (i drive in tiptronic) and then all the sudden I feel the car almost give out, but I'm still moving. So then i give it gas and the RPM's just rev up all the way to like 6k-7k and it HARDLY gains speed. It almost felt as if it was in neutral. It picked up speed barely but it was almost unnoticiable. It doesn't happen in any other gears at all. 1-2-3-4 all pull normally, but once I go into 5th... it feels like its just reving. It almost feels like the gears are just HARDLY grabbing. Enough to keep the cars acceleration going (somewhat), but not grabbing enough to pull. Not sure if anyone has heard of this before or has happened but any help will be much appreciated. If it is too hard to understand, I will try to explain it better. Thanks
Old Nov 26, 2008 | 01:22 PM
g35freak86's Avatar
ahhh shhhhhhhhhhhiiii@#@#@# I think I found the problem.... https://g35driver.com/forums/g35-sed...-03-sedan.html
But I'm still unsure what the cause is and what to actually get fixed. Ughhh definatly an unexpected thing to deal with right now. Especially the before thanksgiving
Old Nov 26, 2008 | 05:54 PM
g35freak86's Avatar
anyoneee?? I'm hoping I just need to flush the tranny fluid. Most likely not the case, but there is still hope
Old Nov 26, 2008 | 06:05 PM
dmitriylm's Avatar
Have you tried driving it in D and seeing if the transmission will automatically shift into 5th and hold revs?
Old Nov 26, 2008 | 06:06 PM
g35freak86's Avatar
yeah I did... it seemed to do the same thing
On the way home today it didn't seem to be doing it as bad as the ride there. But I just kept it in 4th at 3k doing about 60 the whole way home
Old Nov 26, 2008 | 06:17 PM
jjyellow's Avatar
5th gear is prob burned up, time for a tranny rebuild
Old Nov 26, 2008 | 06:18 PM
g35freak86's Avatar
thats my guess. I'm afraid to ask but what kind of $ are we talking for a rebuild?
Old Nov 26, 2008 | 06:20 PM
G35Papa's Avatar
That sounds like what my dad use to tell me were signs of the tranny going bad. He use to specialize in rebuilding transmissions. I'll ask him Chris just to see what he thinks/says.
Old Nov 26, 2008 | 06:21 PM
g35freak86's Avatar
Thanks Chris. I really appreciate that. I'm expecting somewhere in the 2k range I'd say.
Now that this has happened, I am wanting to get into my m3 sooner than ever. ughhh
Old Nov 26, 2008 | 06:22 PM
Jeff92se's Avatar
Red Card Crew
Does each gear have it's own set of bands? I was thinking a shift solenoid that might be assigned for 5th might be going out?
Old Nov 26, 2008 | 06:52 PM
g35freak86's Avatar
I did read something about one of the solenoids going out on a thread on here. Not sure about if each gear has it's own bands, but I'm hoping for the best. Either way, they are going to have to pull the transmission which is a boat load of $ in itself due to the amount of labor
Old Nov 26, 2008 | 06:56 PM
jjyellow's Avatar
Our tranny has 2 bands and they are applied depending on which gear you are in. For a tranny rebuild you prob looking around 2K. Reason its a lil pricey and what some people dont really understand is that you just cant pull out 5th gear and rebuild it, just to get to 5th gear you have to disasseble the entire transmission so a lot of the price goes into labor and they have to warranty the work too.
Jeff92se's Avatar
Red Card Crew
If he hasn't burnt up the bands and if it's a solenoid, he might be able to get away with the shop just removing the valve body and replacing the solenoid.
Old Nov 26, 2008 | 07:05 PM
g35freak86's Avatar
im at 59k so i am wondering if I am still under warranty for something like this. You think?
Old Nov 26, 2008 | 08:38 PM
jjyellow's Avatar
dunno b/c the warranty is 4yr/60k and I see you have an 03. might be worth a shot to ask
