J-matic is now S-matic?
Old Apr 27, 2009 | 02:45 PM
TheTick's Avatar
Just stopped by the dealer to pick up some tranny fluid. They told me that they no longer make J matic and he sold me S matic for $15 a quart ouch! Just want to confirm that this is the right stuff before I do a drain a fill.
This same dealer just told that it would cost 2k to fix my flashing airbag light and there is no way around it. I just did a search here and was able to reset it
Old Apr 27, 2009 | 03:30 PM
TurTLe*'s Avatar
from what i've read yes.
its liek $10 on mynismo.com
and the dealer quoted you 2k to fix it because they are replacing the airbag that threw off the light as a precaution. resetting the light will clear it yes but the light turned on when something with the airbag is wrong. Just letting you know if the same fault happens again or a third time, its time to replace that airbag.
Old Apr 27, 2009 | 03:39 PM
Tangerine's Avatar
$15 per quart? When I paid ~$11 I thought I got ripped off. Yea that is the right fluid.
Just did my drain and refill yesterday =) Very simple and easy. Hardest part IMO was getting off the dipstick bolt and that was easy.
Old Apr 27, 2009 | 03:45 PM
bythabay's Avatar
If your application calls for Matic-J, you can go ahead and use the cheaper, albeit higher quality synthetic Amsoil ATF, which is compatible where matic-j is required.
http://www.amsoil.com/storefront/atf.aspx
APPLICATIONS
AMSOIL AMSOIL Synthetic Universal ATF is recommended for transmissions, hydraulics, power steering and other applications requiring any of the following specifications:
• GM DEXRON® III-H
• Ford MERCON® & MERCON V
• Chrysler ATF+4®
• Toyota Type T-III and T-IV
• Honda Z-1 (Not CVT)
• Diamond SP II & III (Mitsubishi/Hyundai/Kia)
• Mazda ATF-III, ATF-MV
• Subaru ATF
Nissan Matic D, J & K
• Idemitsu K-17
• BMW LA2634
• LT 71141
• Audi G-052-025-A2 & G-052-162-A1
• Volvo 97340
• MB 236.1, 236.2, 236.5, 236.6, 236.7, 236.9 & 236.10
• JWS 3309
• NAG 1
• ETL-7045E, ETL-8072B & N402
• Voith 55.6335.XX (G607, G1363)
• ZF TE-ML 03D, 04D, 09, 14A, 14B, 14C, 16L, 17C
• Allison C-4, TES 389
Old Apr 27, 2009 | 06:28 PM
TheTick's Avatar
Thanks guys... I'll stop by riverside infiniti next time I'm in the area and stock up on the s matic.
Not sure what triggered the airbag light, but if it is a bad airbag, I'm sure the light will come back. Keeping fingers crossed. For some reason I thought that airbags were covered longer than standard warranties.
Old Apr 27, 2009 | 10:03 PM
5150DS's Avatar
APPLICATIONS
• GM DEXRON® III-H
• Chrysler ATF+4®
• Subaru ATF
• Idemitsu K-17
• BMW LA2634
• LT 71141
• Volvo 97340
• JWS 3309
• NAG 1
Any problem with mixing the Amsoil with the Matic J?
Old Apr 28, 2009 | 03:25 PM
ttrank's Avatar
Grocery getter
Drain and re-fill, don't mix. If there is a little in there from before that does not come with a drain, that's ok.
Old Apr 28, 2009 | 05:40 PM
bythabay's Avatar
You can only drain out about 3.5 qts, the entire capacity is 11qts. It should be just fine to mix, they are compatible fluids.
Old Apr 29, 2009 | 04:57 PM
Q45tech's Avatar
JATCO the manufacturer of transmission provides the warranty to Nissan which then passes it on to you.
JATCO has a method of catching non compliant ATF by chemical analysis of ATF.
But generally this never comes into play since the warranty expires at 70k or 100k at extra cost.
$165 is cheap if it prolongs the AT life by even 6 months since 10 year life equates to $450 per year as the cost of using transmission.
Old May 2, 2009 | 05:26 PM
mikeee2's Avatar
I bought Matic J two months ago and they were about $12 a quart (before tax). Today I went to a different Nissan dealer and bought Matic S (they don't sell Matic J anymore) for about $11 a quart (before tax).
I asked the parts dept if I can mix Matic J with Matic S and the guy said absolutely. He said there were some additive they've added to Matic S but other than that he said it's the same fluid but with a new name.
Old May 4, 2009 | 04:20 PM
MardiGrasMax's Avatar
Redline D4 also meets J spec. Ive had it in my trans for 20k, doing a flush soon.
Old May 6, 2009 | 02:00 PM
mesias's Avatar
I got from InfinitiPartsUSA 8 qts of Matic S for $75 shipped. They sell each qt at $7.99 plus shipping. This is the best deal I found
Old May 6, 2009 | 02:25 PM
infinus's Avatar
mynismo.com has it for 8.95 a qt
Old Jun 26, 2009 | 07:08 PM
Shincrono's Avatar
$7.95 a qt on thenismoshop.com
Ferrarimanic360
May 12, 2014 05:14 AM
Maciuniu
Dec 10, 2012 08:39 AM
saltyload
Jul 7, 2012 11:30 PM
railer
Canada
Feb 22, 2011 09:06 PM
