DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
Old Jan 12, 2010 | 11:54 AM
  #46
SDGenius's Avatar
still waiting on an answer
Old Jan 14, 2010 | 09:22 AM
  #47
SDGenius's Avatar
okay, this WILL fit after the changes right? i'm about to pick one up.
Old Jan 14, 2010 | 09:40 AM
  #48
SyCo's Avatar
Yes but remember it is NOT a 100% bolt on swap.
If it looks like the 2007 I've posted and if you are able to swap the flange and the dust cover and cut the pinion shaft, YES it will fit 100%.
The only special tools I needed were a puller for the flange and an angle grinder with a cutting wheel.
It's currently installed under my 2003 G35 5AT. I will take pictures tonight since my car is in the garage.
Old Jan 14, 2010 | 09:49 AM
  #49
SDGenius's Avatar
okay, great. it's from an 08 haven't seen it in person, but the 07-08 have the same setup. if i don't have these tools, are they pretty common? what type of shops would prob have 'em on hand?
Old Jan 14, 2010 | 10:06 AM
  #50
SyCo's Avatar
Yes pretty common. To my knowledge, all shops would have those tools on hand.
Old Jan 14, 2010 | 10:09 AM
  #51
SDGenius's Avatar
yay!!!
Old Jan 14, 2010 | 10:33 PM
  #52
Inspired's Avatar
woohoo someone from quebec haha, where in Qc are u?
  #53
Inspired's Avatar
nice mod btw i was looking for something like this
Old Jan 15, 2010 | 08:10 AM
  #54
SyCo's Avatar
yay!!!
Here are a couple pics I took this morning
Thanks ! ... and I'll be doing some more... I'm from Saguenay so it's about 5 hours from you
Old Jan 15, 2010 | 01:26 PM
  #55
Inspired's Avatar
its k i like driving we have to do a meet this summer. but not now my car is stored also. from where can i find a g37s differential? im trying to look for one also
Old Jan 15, 2010 | 01:46 PM
  #56
Jeff92se's Avatar
Red Card Crew
Let us all know how it drives as far as accel, mpg and cruise control. For me, 3.3 to a 3.7 is a 11% gear difference.
Old Jan 15, 2010 | 02:03 PM
  #57
SyCo's Avatar
Yeah probably can work something. I often goes to "Pont-Rouge" drag strip and I might also go to some events near Laval.
To find one I'm not sure, since you're in a big city call a couple junkyards and probably that you'll be lucky. I've found mine on "Lespac.com" in Sherbrooke. I recently saw a 370Z complete for parts but I'm not sure if the seller want to part out. In the past I also saw 3.5 from a manual but not sure if that's what you looking for.
Yes sure I will but only in a couple months. I will even go to the drag strip. Maybe SDGenius will come back with feedbacks before me though.
I will also check for the CC cause it may still works on speed below 80mph according to what I've read.
I can also give you my MPG but I did not record it before the swap, so it may be of no great value since each car/driver is different.
Old Jan 15, 2010 | 10:12 PM
  #58
Inspired's Avatar
where's pont-rouge exactly?
Old Jan 15, 2010 | 10:13 PM
  #59
Inspired's Avatar
usually i go to st-eustach and mirabel, its not that bad u should come one day
Old Jan 15, 2010 | 10:35 PM
  #60
SDGenius's Avatar
lookin' forward to getting mine
