DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
Old Jan 27, 2010 | 11:42 PM
  #91
SDGenius's Avatar
nah, i got the diff for $260 shipped. $400ish for the install
Old Jan 28, 2010 | 01:40 AM
  #92
DaveB's Avatar
What? On a lift and with a tranny jack, swapping this thing in shouldn't take a tech any longer than 1.5 hours. That's a crazy hourly rate.
Old Jan 28, 2010 | 01:45 AM
  #93
SDGenius's Avatar
it was a rough est, he said most likely lower... he just wanted me to know "worse case" in case of complications. they also warranty all parts to come out of their shop.
Old Jan 28, 2010 | 01:23 PM
  #94
OCG35's Avatar
$400 is about what it costs to install the actual gear set... just swapping pumpkins should be quite a bit cheaper...
when are you doing it Mark?
Old Jan 28, 2010 | 02:40 PM
  #95
Tollboothwilley's Avatar
Wow. If you have to pay that much for the install, then you're getting ripped off. I hope he doesn't try to charge you that much.
Old Jan 28, 2010 | 08:42 PM
  #96
SDGenius's Avatar
not sure when i'll have time to get it done, he still has to have his tech check out this thread. i'm guessing he thinks the mods to make it fit are more than they are. so what do you guys think a fair price is?
Old Jan 28, 2010 | 08:48 PM
  #97
OCG35's Avatar
oh, yours is a 3.7 from a 37 right?... if that's the case I'm not sure what (if any) special considerations need to be made...
But 3.5 shouldn't be a big deal... $200 - $250 maybe? Whats the shop's hourly rate?...
  #98
Jeff92se's Avatar
Red Card Crew
Probably depends how much time he needs to take to swap the input flange. After that, it's probably really straight forward. Hopefully he's just overestimating to prevent undercutting himself. 2 hours @ $75 and hour at the most?
Old Jan 28, 2010 | 08:51 PM
  #99
OCG35's Avatar
^^^ I used $75 per hr too - but calculated 3 hrs (error on the high side)...
so $150 on the low end (if there are no problems and they are swift) to $250 (giving leeway to higher shop rate and potential additional time from delays)...
Old Jan 28, 2010 | 09:02 PM
  #100
Jeff92se's Avatar
Red Card Crew
If he could get his hands on an G35 input flange (or whatever it's called), he could probably do that himself and then just ask the mechanic to do the actual swap.
I'm actually looking around for a spare diff that I can raid the input flange, axles and rear diff cover from.
Old Jan 28, 2010 | 09:20 PM
  #101
SDGenius's Avatar
thanks or the input guys, i'll def mention that next time i give 'em a call
Old Jan 28, 2010 | 09:42 PM
  #102
SyCo's Avatar
Here is my "guesstimate" from what I remember and if we assume I did it in my own garage without a lift but with at least the right tools (a puller and an angle grinder or similar to cut the shaft).
0- Drain oil from "old" diff ~5-10 min.
1- disconnect driving shaft (four bolts) 10 min.
2- disconnect both axles (twelve bolts) 30 min.
3- disconnect breathing tube and abs sensors ~ 2 min.
4- remove pumpkin (two bolts + 1 nut) 10 min.
5- remove and pull flange from "old" diff (1 nut + puller) 5 min
6- remove and pull flange from "new" diff (1 nut + puller) 5 min
7- swap the "dust cover". It is kind of press fit and quite simple to swap 5-10 min
8- install the 03 flange on the "new" diff (one bolt) 5 min
9- cut input shaft (angle grinder with cutting wheel) 2 min
10- reinstall the new diff following steps 4,3,2,1 ~ 52 min
11- put oil in the new diff 10 min
12- DRIVE !!!
I did took my time so as you can see it should take at most 2.5 hours (175-200$).
You can also note that swapping flanges is really easy 15 minutes at most and that's including time to figure how to swap the dust covers.
Don't forget to give your comments once done
Old Jan 28, 2010 | 09:57 PM
  #103
SDGenius's Avatar
cool... hmm at that price, i may get it on sooner
Old Jan 30, 2010 | 12:51 AM
  #104
Ya, I would figure 2 hours of labor for a mechanic. With a lift and everything it should be pretty damn quick.
Old Jan 30, 2010 | 03:26 AM
  #105
KSWAY's Avatar
Getting mine tomorrow, Out of a 2007 S with about 50K on it. The guy has a parts car with complete interior, motor and tranny. So if any of you need parts from the car let me know.
