Clutch Noise When Shifting at higher rpm
Old Dec 24, 2020 | 12:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That sounds more like a worn throwout bearing causing the noise, but the pedal being slack is a definite sign of either air in the lines, bad CMC, or bad CSC. Slight chance that the TO bearing kaboomed and is physically broken and thus the noise but it's usually VERY VERY obvious that you lost a TO bearing.
Old Dec 24, 2020 | 02:55 PM
C_infty's Avatar
G35C M/T
Yea I'm probably gonna just get all the clutch bits replaced sometime when I'm out of the Bay Area to save on labor. I'm shocked how cheap clutches are for these cars lol, definitely not used to it, as this is my first high-production-volume platform.
It does sound a bit like a much faster version of dead throwout bearings that whine at idle, but the complete silence below 4000rpm is very puzzling. Or maybe my hearing is bad (but I don't think it's THAT bad lol).
Old Mar 14, 2021 | 06:10 AM
C_infty's Avatar
G35C M/T
Thought I would try consulting the wisdom of the forums again...here's a recording of it. I fixed most of the weird exhaust rattles so this noise really stands out. It's louder than everything else. Most prominent around 5000rpm, dead silence from the clutch below 4500rpm. I get some pedal vibration but it could just be the engine's vibration.
I've driven the car a few thousand miles already and there have been zero issues so I am considering just leaving the clutch as is. The clutch bites very high but the internet seems to agree that's how it is from the factory.
File Type: mp3
Old Mar 14, 2021 | 11:57 AM
cleric670's Avatar
BANNED!!!
Are you talking about that momentary sound at the top of the rpm band with the clutch in?
EDIT: Are you sure it's rpm related and not CLUTCH PEDAL related? Almost sounded like a squeaky pedal.
Old Mar 14, 2021 | 04:51 PM
C_infty's Avatar
G35C M/T
Yes, I held the pedal down and didn't move my foot, and revved the engine. The whining noise changes pitch with engine speed but only exists over 4500rpm.
Old Mar 14, 2021 | 10:19 PM
cleric670's Avatar
BANNED!!!
Probably a worn throwout bearing, how many miles are on it?
Old Mar 15, 2021 | 01:51 AM
C_infty's Avatar
G35C M/T
Probably, it doesn't seem like anything else would be capable of making that sound. I have no idea how many miles are on it. It's just strange to me that a bad bearing could make no noise under most conditions.
Old Mar 15, 2021 | 12:33 PM
cleric670's Avatar
BANNED!!!
It's probably making noise under all conditions, but it just gets significantly worse at that rpm range.
jdubin94
Dec 11, 2015 08:19 PM
izzueeek
Aug 17, 2010 08:53 PM
Synapt
Drivetrain
12
Feb 24, 2010 05:09 AM
1ceman
Oct 23, 2007 09:24 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
