DIY: 5AT to 6MT SWAP.
Rating: Thread Rating: 4 votes, 4.75 average.
Old May 8, 2012 | 11:10 AM
  #91
Sparda1123's Avatar
Bump
Old May 10, 2012 | 04:10 PM
  #92
DEMoLITIoN's Avatar
update, as requested. woot!!
Old May 11, 2012 | 04:25 PM
  #93
Sparda1123's Avatar
You are da man! Now for a dumb question is the EFI harness the one thats on the engine or the dash? Also will osiris be able to reflash the 5AT to a 6MT?
Old May 15, 2012 | 03:30 PM
  #94
DEMoLITIoN's Avatar
The EFI harness is the engine harness It connects from the engine and all sensors to the ECU and interior. Osiris will be able to remove the codes you will get when you keep the 5AT ECU. more on wiring and stuff within the next two weeks. The clutch pedal is in but there is no real simple, cookie cutter way of doing it. You just need to go down there and mark it. then drill.
Old May 15, 2012 | 05:05 PM
  #95
Sparda1123's Avatar
Ah if thats the case i need a tune anyway so i may as well just keep the 5AT ecu and wire up the nutreal switch and reverse lights and that switch to the clutch pedal. What would really be cool is to figure out a way to have the 5AT gear indicator indicate what gear your in when you swap it to manual. Then again i dont think it can display a 6 so for 6th gear so your stuck.
Old May 16, 2012 | 09:59 PM
  #96
Charles13's Avatar
can you give some more info on the clutch pedal and clutch master cylinder install.
Old May 17, 2012 | 07:20 PM
  #97
DEMoLITIoN's Avatar
Yes, but a writeup for this part won't help. It is probably the most frustrating part of the swap. All I can say is line up the clutch pedal next to the brake pedal, then mark the holes. You with drill. I will provide pictures but you'll see what i'm talking about. The pedal was not installed 100% OEM as the car did not have the indents on the firewall. It is kind of lopsided but it works. I will actually be redoing this with an internal willwood setup. more pics to come...
Old May 17, 2012 | 09:18 PM
  #98
Charles13's Avatar
Okay, so the pedal is only secured by the two bolts from the master cylinder? Nothing for the top hole on the pedal?
Old Jun 1, 2012 | 09:14 AM
  #99
Sparda1123's Avatar
Bump? BTW happy friday i might start this project finally just got my bonus
Old Jun 2, 2012 | 01:32 PM
  #100
DEMoLITIoN's Avatar
I have not had time to update this. I will put it back on the lift when I do the wiring.
Old Jun 4, 2012 | 01:53 AM
  #101
Sparda1123's Avatar
All good man thanks for the work thus far! I'm still debating what I want to spend money on.
Old Jun 22, 2012 | 03:10 PM
  #102
Sparda1123's Avatar
Im surprised this thread hasnt been stickied for all the "is it possible to swap my 5at to 6mt?" threads
Old Jul 5, 2012 | 02:21 PM
  #103
DEMoLITIoN's Avatar
update soon...
Old Jul 9, 2012 | 10:40 AM
  #104
Sparda1123's Avatar
^ Thank you i was actually just thinking of it today. Being i got my tune my last power adder for a while will be cams but thats going to be expensive so i think il focus on this project next. I gotta play with osiris though to make sure i can kill the codes im going to get from the TCM. If not im going to have to hunt down a 6mt ecu wiring harness and gauge cluster (which id love to do but those parts are kind of hard to find)
Old Jul 9, 2012 | 10:20 PM
  #105
pure sex's Avatar
I think we would all love to see the wiring you did with the 5at harness and some pics of the clutch pedal installed. Thanks for all you have done so far.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
