DIY: 5AT to 6MT SWAP.
Rating: Thread Rating: 4 votes, 4.75 average.
Old Mar 18, 2022 | 03:43 AM
  #256
Infiniti/23's Avatar
4 dr auto silver base open diff. 6mt swapped.
Originally Posted by AbyteZero
Context:
G35 Sedan A/T 2003 with parts from Coupe M/T 2003 [ Engine + Transmission + Computer (driver side under the steering) + Computer (passager side over his feet)]
Just connected #26 to #43 according to this document and it works :-D
So I jumped inside the IPDM box the wire #43 to the empty #26 (because IPDM from the A/T car)
Page 12
http://www.nicoclub.com/FSM/G35/Sedan/2003/sc.pdf
really hate to dig up this old thread but I wired the reverse sensor and pns switch and they both work fine, I don’t recall the pin numbers, but I don’t remember seeing 26 and 43. What are they for? Reason for asking is I’m having trouble with my car locking up the brakes because it sees slip and my AT check light is on as well. I can go 5 feet before the front brakes are totally locked up and the car just has a very weird one tire fire. I’ve cleared the codes, but they come right back, so they’re “hard” codes. Wondering the purpose of these two pins. I didn’t pin wire 53 in the ipdm because I think that was just to get the car to start, and mine starts just fine. Any help provided is greatly appreciated. Thanks in advance.
Old Mar 18, 2022 | 03:48 AM
  #257
[QUOTE=cotten;7180004]Did anyone here reference the e brake relocation? Just seeing if i missed something. Does it just simply bolt in?[/QUOTE
its not a straight bolt in, but I used the center console to get an idea of where it lined up at, and was able to reference one hole pre drilled for something else, then I drilled another hole and used to bolt and nut. Mine reached fine. I had to all but unbolt everything involving the cables, and would’ve been easier to drop the driveshaft, because it’s tight under there and I had to spray the hell out of the cable heads to get them loosened and freed from their position in the clasp, but I got the old one removed and the new ebrake handle and clasp installed and everything bolted up fine. My ebrake is a little off, but it still tightens just fine and looks okay inside. I made a YouTube video of it if you’re interested in that, just reply or send me a message and I’ll give you the link
Old Mar 18, 2022 | 04:18 PM
  #258
Ecu swap
[QUOTE=elie;7145160]
Originally Posted by DEMoLITIoN
HAPPY SHIFTING!!
[/QUOTE
hello, I'm new here i made this swap at a garage but he didn't flash my ecu the car runs but its kinda got weak so i wanna buy the 6mt ecu since it's cheaper than a flash, my car is an 05 g35 and i was wondering if i should buy the 04 6mt ecu sincd the 05s 6mts came with revup and the auto didn't... and if i swaped the ecu will just be plug and play or should i change something in the wiring?
did you ever get your answer?
Old Mar 18, 2022 | 06:22 PM
  #259
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Originally Posted by Infiniti/23
my car keeps saying A/T and slip, and it’s locking the brakes up so it won’t go anywhere. Any suggestions on what I can do to fix this?
Sounds like you haven't flashed the ECM to 6MT yet and it's still configured as a 5AT ECM.
Old Mar 18, 2022 | 06:33 PM
  #260
Flash
I was under the impression you didn’t need to flash the ecu. It just says you can use 5at ecu. Nothing says you need to get it reflashed. Guess I’ll send it to uprev. Thanks for the info
Old Mar 18, 2022 | 08:24 PM
  #261
cleric670's Avatar
BANNED!!!
There's ways to do this without sending it to uprev, I strongly recommend reading a few threads on the 6MT swap.
It's probably cheaper just to buy a used eBay G35/350Z 6MT ECM (with the correct plug for your car, 3 total options across model years) rather than sending it to Uprev but if you do plan on tuning the vehicle later you should talk to @seymore4 he can probably shed some light on things better than I can.
Old Mar 18, 2022 | 08:46 PM
  #262
thanks for the advice. I researched this for a long time before actually deciding to do it, and nobody clearly states that you need to reprogram anything. Not one thread states that it’s a necessity. In fact, they all suggest and make it seem as if uprev tune and ecu swap is a dumb idea, but nobody has stated the way to use the 5at ecu. So it’s all a grey area. I’m too afraid to ask the necessary questions because I feel like somebody is going to jump my s$1t and tell me to use the search bar, like it has all the answers or something. It’s hard to get clear answers on certain matters because you always have those guys that don’t wanna answer questions to help other people out. Like they figured it all out and are too good to divulge the holy grail of info, so I guess like everything I do successfully, I’ll just figure it out on my own. Just seems the car is going to sit and I’m gonna be in a casket at a ripe old age waiting for somebody to stop beating around the bush and give the the exact answers I need. Getting answers in todays society is like pulling teeth. I’ve done the hard work and the swap is complete, and you can’t even tell it’s been done, so I’m happy with it, but I will get a 6mt sedan ecu and drag the car to Infiniti and have all reprogrammed, because we all know it’s the greatest adventure taking any of our cars Nissan/Infiniti to the dealers and sitting through their bullshit and half the time going home empty handed because they just don’t wanna do anything for you unless you’re throwing a small fortune in their faces, along with three already dead hookers, complete with coke lines on their backs, and the tried and true arm and a leg, just to get simple things done. In all the babbling, to sum it up, I’ve been asking the same question for weeks, to get nearly similar answers from people. Either they know or they don’t know, but they always have to slide in their shot of YOURE an idiot, because they can’t answer your questions. I do everything myself because I hate dealing with people. If I had to ask somebody to hand me the salt and pepper, I’d have to wait longer, hear what they have to say, and deal with the consequences, when it’s easier to quietly get up and get the salt and pepper myself. Cut people out of the equation and my things get done much faster and better. Thanks for you’re help man.
Old Mar 18, 2022 | 09:36 PM
  #263
seymore4's Avatar
m56
You need to flash the ECU for the MT swap. You CAN get a matching 6MT ECU and install that instead, but then you have to get the keys programmed and if you're going to spend all that money, why not just spend a little more and get a tune as well.
You can't send the ECU to Uprev tho, they don't do this kind of stuff directly. I do tho Shoot me a PM I can help you out
Old Aug 29, 2022 | 12:09 PM
  #264
devin26's Avatar
04 g35 5at-> 6mt. cold air intake. bc coilovers. bullhoost diff weld.
Help
So ive done this 6mt swap on my 04 g35 sedan, everything was fine for quite some time (approx 3 months) all of a sudden no throttle response. I have changed the gas pedal and the throttle position switch 3x trying to fic problem no fix found. Anybody have any alternatives to what this problem coild be. Do I need to switch to a manual 6mt ecu with harness maybe chrck my throttle body, get a full reset on my 5at ecu? Any recommendations please
Old Aug 29, 2022 | 04:58 PM
  #265
cleric670's Avatar
BANNED!!!
If it worked for 3 months then suddenly stopped then just something that broke. Start with an OBD2 scan for hidden codes, you can realtime scan for both throttle input % as well as actual throttle position %.
You can also pull the intake, key to ON position, and work the gas pedal while you watch the throttle plate open/close. Non rev-up DE engines can do this. Rev up engines cannot.
Old Sep 6, 2022 | 11:15 AM
  #266
VQNoob97's Avatar
6mT swap
Originally Posted by jdm-v35
if the key is not programmed it will crank forever but never start up and run.
so I completed my swap but this is the issue I’m running into. My security light blinks and I brought someone out to program the key but they couldn’t program it. Key turns but fob key fob could not get programmed. I don’t know what to do at this point. Car cranks but no spark and all wiring is done.
Old Mar 26, 2025 | 04:06 PM
  #267
Tyego2hard's Avatar
In process of swapping blown auto for manual
Hello
I am looking for help with swap, I’m from St. Louis mo
No. I'm willing to do CHEAP work on anyone who needs this done. Any takers in the SF Bay Area? It's very simple to do. I do not know about the shift light. I'm sure it does. You will need the 6MT cluster.
Old Mar 26, 2025 | 07:05 PM
  #268
n1ckyd18's Avatar
I’m doing this swap on my 05 coupe. If I wire as directed and reflash ecu. Will I have abs and vsc?
nyqueenz
18
Mar 7, 2012 12:26 AM
Canadian
Picture Share
113
Oct 2, 2011 07:24 PM
lookthatsme
Drivetrain
Aug 8, 2010 06:04 PM
SPEC-01
Drivetrain
Feb 13, 2009 10:08 AM
HwyDrftr
Sep 7, 2006 02:18 AM
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
