DIY: 5AT to 6MT SWAP.
Rating: Thread Rating: 4 votes, 4.75 average.
Old Aug 22, 2012 | 08:56 AM
  #121
Sparda1123's Avatar
Just a thought, (which im not sure is possible or not) but has anyone thought of wiring up the gear position display up to the 6MT that way those that use the 5at gauge cluster can have the display telling them what gear theyre in. If possible id like to do this my self i think it would be pretty pimp for that to work so you dont just have a blank screen there.
Old Aug 22, 2012 | 06:20 PM
  #122
pure sex's Avatar
The only problem is there is not switch in the 6mt that tells what gear it is in. So you would have to make a switch.
Old Aug 22, 2012 | 06:50 PM
  #123
JaE35's Avatar
Moderator
G35 Sedan
easier to just get a 6mt harness if you don't have an 04.5 auto lol...just went through that mess
Old Aug 24, 2012 | 09:44 AM
  #124
Sparda1123's Avatar
Yea ive thought about that but i think it would be just easier to wire the reverse and neutral position switch and i can just turn off the codes that it will throw with my osiris.
Old Sep 28, 2012 | 03:31 PM
  #125
Sparda1123's Avatar
Any Updates on wiring?
Old Sep 28, 2012 | 04:27 PM
  #126
DEMoLITIoN's Avatar
yea, on the first post.
Old Oct 18, 2012 | 12:08 AM
  #127
MPG35fiend's Avatar
awesome write up man!! make it look so easy....
Old Dec 6, 2012 | 11:30 AM
  #128
Swang&BANG350GT's Avatar
I will be doing this along with my new motor within a few weeks. i will have the 6mt ecu though.
Old Jan 20, 2013 | 11:55 PM
  #129
so ive finished the 6mt swap everything is put back together and wired up using the first method. I ran into in issue of the car not wanting to start. What did u do to the TCM to not make it show a U1001 code or did u do anything to the TCM!? My starter wont even click over so in suspecting that it maybe that...idk!!!
Old Jan 21, 2013 | 02:27 PM
  #130
Charles13's Avatar
Did you have the key reprogrammed to the new ECM? I had the biggest trouble with mine until I got the 6mt ECM and harness for my same year..after I did that had the key reprogrammed by a locksmith and viola started first try and has been running since.
It sounds like your having a issue with the nats system being enabled..if you swapped out the ECM you will need to have the key reprogrammed with the bcm and ECM
Old Jan 21, 2013 | 03:01 PM
  #131
I have my regular 5 at ecu. I have 6 my one but no harness. Idk what it is and that's the only thing holding me up!!!
Old Jan 22, 2013 | 02:55 AM
  #132
Charles13's Avatar
I jiggled with mine for a month or so with my old auto harness and a 350z 6mt ECM and I always had to do a released pedal relearn...but that was after getting the key originally programmed to that ECM.
Have you tried starting the car with both ecm's? If so that might've done it too and might need a reprogram.
When you have the key in the "on" position does the red light on the dash stay lit up solid?
Old Jan 22, 2013 | 04:55 PM
  #133
I got it to work...i didn't have a good connection cause I was using those blue clips that u can splice wires together. I removed some sheathing off of the wires and wrapped the others around them making a solid connection....started right up after that!!!
Old Jan 22, 2013 | 05:27 PM
  #134
JaE35's Avatar
Moderator
G35 Sedan
Yea i was going to say it had to be something with the ignition wiring
Old Mar 20, 2013 | 10:51 AM
  #135
Jtrain's Avatar
Just burnt my 2nd built AT tranny. Think I'm going to have to dive into this now.
Thanks for adding pictures!!!!!!
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
