06 Transmission Speed Sensor location
Old Oct 23, 2019 | 05:46 PM
J Guff's Avatar
G35 Coupe Base
I recently got a great deal on an 06 with 115k miles. It has the slip light and VCD off light on. After some research and pulling codes it seems the transmission speed sensor is bad. I cannot seem to find it to remove it. Can anyone help me find the sensor or give any pointers for replacing it?
Code is P0720
Old Oct 23, 2019 | 06:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Turbine revolution sensor is inside the tailshaft housing of the 5AT.
-Disconnect battery
-Drain transmission fluid
-Remove exhaust y-pipe
-Remove driveshaft
-Remove shift linkage
-Remove fluid pan
-Support transmission with a jack, remove engine mount and crossmember
-Remove tailshaft extension bolts and remove tailshaft extension
-Turbine revolution sensor is now accessible, it plugs into the front harness on the valve body/TCM, pay attention to how the wire is routed through all those little metal "fingers" that holds it into the proper place.
Unbolt, get a new one, installation is in reverse.
Torque specs for everything are listed in the FSM, section AT - Automatic Transmission starting on page AT - 246
That's why you got a great deal on it It's about a 10 hour job.
Old Oct 23, 2019 | 09:11 PM
J Guff's Avatar
G35 Coupe Base
-Disconnect battery
-Remove driveshaft
-Remove fluid pan
Still worth the 600 I paid
Thanks a lot for a good jumping off point. I printed all the relevant FSM pages and I should be all set now.
Old Oct 23, 2019 | 10:13 PM
cleric670's Avatar
BANNED!!!
Yeah it's actually a really EASY fix it's just super time consuming.
Depending on the mileage you should probably plan on replacing that transmission output shaft seal while you have the tailshaft off. Press on it around the entire diameter with your finger and if the rubber isn't pliable just install a new one.
EDIT: the seal at the end where the propeller shaft goes in.
Use Matic J or Matic S transmission fluid.
Old Oct 24, 2019 | 09:27 AM
G2B35AGN's Avatar
Maybe put in a TransGo kit too while you are monkeying around with it....
Lil_Spanish
Mar 13, 2019 03:05 PM
Gorhad
Apr 7, 2015 11:15 AM
BabySkyline
Jul 23, 2013 08:53 PM
rwcblkcoupe
Mar 5, 2011 05:58 PM
