Clicking axle fixed!
Old Mar 9, 2011 | 03:55 PM
  #151
OKStateG35's Avatar
Originally Posted by sch4400
I have a fx35. I did this. it's easy. not a hard job. only hard thing is to buy right grease.
I was ordered on nissan part at west covina. It was around $150 I think..
You could have bought any generic moly-fortified grease at your local auto parts store. I bought Valvoline for less than $10.
Old Mar 14, 2011 | 01:21 PM
  #152
Hybird's Avatar
Agreed. I picked up a package of "Dormans Help Products" cv axle grease from Partsource for about 10 bucks. Its actually supposed to be used on the axle joint when you change a CV boot. That was nearly 6 months ago. Click has not come back. I'm pretty sure the grease chemical composition is not a strict requirement ha.
Old May 24, 2011 | 10:18 PM
  #153
curin323's Avatar
i had this problem too. help
Old May 25, 2011 | 11:36 AM
  #154
viceversa's Avatar
I remember there used to be a video on infinitihelp outlining the procedure for fixing this but I cannot find it anymore. Anyone know if there was a video or am I crazy? lol
Old May 25, 2011 | 12:48 PM
  #155
Blue Dream's Avatar
I drove ttrank's car solo
Do a search on My350 and enter "Clicking axle fix". There's a great DIY but I'm at work and don't have time to search for you, sorry.
Old May 25, 2011 | 04:22 PM
  #156
viceversa's Avatar
^yeah thats right here
I just want to know if I'm crazy about if a video did or did not exist at one point. no worries
Old May 25, 2011 | 04:39 PM
  #157
importroller's Avatar
how do you diagnose if this is a problem you are currently experiencing. Right now, I hear a popping noise when I let up off the brakes, but not sure if this is what we are talking about here
Old May 26, 2011 | 09:01 AM
  #158
viceversa's Avatar
^there is a video in the link i posted above.
Old May 26, 2011 | 09:48 AM
  #159
OKStateG35's Avatar
Mine would make the click/pop when I put it into reverse to back out of my driveway. It would also do it when accelerating from a stop. Don't remember anything specifically related to the brakes, but it basically made the noise anytime the car started moving forward or backwards from a stop.
Old May 26, 2011 | 01:18 PM
  #160
thats pretty much how mine is, as soon as i release of the brake to start moving, i hear the pop/tick noise, and its much louder than whats in that video. I guess I'll have to get some grease this weekend, and get to work.
Old May 26, 2011 | 03:23 PM
  #161
viceversa's Avatar
I would also say that clicking in that video is not nearly as prominent and loud as my clicking. Anytime i go from reverse then slightly move forward and repeat it drives me nuts. I will be fixing mine this weekend and will report back. Also I plan on just using the Valvoline SynPower grease but will be replacing all nuts and bolts.
Old Jun 13, 2011 | 12:05 PM
  #162
trentor's Avatar
Thanks to all for all the great info. I did this yesterday. It took me forever, but that's nothing new.
Old Jun 13, 2011 | 12:55 PM
  #163
viceversa's Avatar
Also did mine this past weekend and the clicking is gone! w00t w00t. some words of advice from doing this is that removing/re-installing was the hardest part. I found that if you unbolt the sway bar link bracket which is attached to the frame by 2 bolts. It makes it 100x easier to get that axle in and out of there.
Old Jun 25, 2011 | 10:36 PM
  #164
IIIHawKIII's Avatar
in that DIY guide it says to put the wheel back on and put the car down, then undo the axle bolt...but how would you do that with the wheel on?!?
Step 1:
Lift rear of car with jack, remove lugs and wheel.
Step 2 (if applicable):
Remove wheel spacer. Cotter pin will not come out if left on.
Step 3:
Remove Cotter Pin. Use pliers to straighten the long, bent end and slide out.
Step 4:
Put wheel back on and tighten lugs.
Step 5:
Lower Car to ground, Start engine (for brake assistance), apply brakes. This will prevent the car from moving when you go to step 6. If you don't apply the brakes the torque you apply will only spin the axle instead of unscrewing the nut. You may not have to put your car on the ground but there is so much force being applied you can rock the car enough to push it off the jacks.
Step 6:
Using a breaker bar, 32 mm axle socket, and extension/cheater bar/pipe remove the axle nut. It's on there tight! Use a beefy enough breaker bar and long enough pipe and it will come off. If you use a smaller breaker bar it can sheer the end off as shown, like I said, it's on there tight...
Step 7:
Raise car, place on jack stands, remove wheel. (Some remove the caliper and brake rotor, I completed the service without performing this step and didn't have any issues).
Old Jun 26, 2011 | 10:43 AM
  #165
viceversa's Avatar
^you would remove the center cap from the wheel and from there would have access to the nut while the wheel is on. I was able to remove the nut from just using the e-brake and did not have to put the wheels back on.
