hmm i dont know whats wrong with my car..
Old Apr 23, 2007 | 06:47 PM
binar's Avatar
Originally Posted by cchaorule
but this happens when im in gear with the clutch not engaged and i floor it.. it still doesnt catch right away
kk that post doesn't make sense... sorry..
I agree with everyone else, clutch.
If you are saying that you floor your accelerator without having the clutch fully engaged... well then that is a major problem... don't do that.. ever!
You should always engage the clutch as soon as possible. From the lowest RPM's possible. Unless you are launching your car quickly.. then you raise the rpm's higher before starting to engage the clutch.. but you always fully engage the clutch asap once you start... does that make sense??? Just get your foot off the clutch.... nuff said!
Old Apr 23, 2007 | 07:21 PM
Kev G35's Avatar
so is it ok that give it a little gas first then engage?? let's say around 1.5K RPM then engage the clutch. am I burning the clutch that way??
cuz when I do that RPM raise first then drop when I start accelerate. is that called slipping clutch? thanks..
Old Apr 23, 2007 | 07:24 PM
cchaorule's Avatar
i meant like when i have the car in gear just cruising with the clutch completely out... and i accelerate... the rpms would still jump up and come down because it doesnt catch right away.. anyways i am going to replace my clutch... i plan on going forced induction in the summer.. so what kinda clutch do you guys think i should get??? thankss
Old Apr 23, 2007 | 07:48 PM
binar's Avatar
This part is good.. it's what you want to do.. give a little gas... engage the clutch gradually... when you start to feel the car move... give a little more gas and fully engage the clutch
Slipping the clutch is when you get to that 'starting to engage' point that I just talked about and you hold your foot there while you press on the accelerator...
you usually only slip your clutch if you want a fast launch and don't want to spin your tires... or bog your car from the tires having too much grip.(all wheel drive cars have this issue)..
you can also slip your clutch to go slower than the gear allows.. when you need lots of torque and not much speed.. like getting up my driveway and into my garage..
You have to think about what is going on.. your engine is producing a LOT of energy when you give it a lot of gas.. that energy has to go somewhere. If it doesn't go through your transmission to your rear axle..then your clutch is absorbing all of that energy... make sense...???
Go here for a good explaination on automotive clutches..
Old Apr 23, 2007 | 08:22 PM
Kev G35's Avatar
I am glad that I am doing the right thing so far. Thank you!
Thanks for the link, but I've read all that before already, but for me I'd like to find some "live answer" when the actual question comes to me. the explanation above sounds like "burning the clutch". are they the same? Thanks!
Old Apr 23, 2007 | 09:10 PM
binar's Avatar
Slipping the clutch too much will lead to the burning of the clutch..
you will smell it... schtanky..
Old Apr 23, 2007 | 10:02 PM
j-champaco's Avatar
feathering the clutch - just get it replaced!
Old Apr 24, 2007 | 07:25 PM
kvangil's Avatar
That's how a bad/slipping clutch acts, from personal experience with my old car (although it took me 138K miles to burn that clutch). Even if you're not engaging the clutch, you will see your rpm's jump before it finally comes down, and you pick up speed. Congrats!! You've now experienced a slipping clutch! But since you're planning to change out your clutch, you'll notice that it won't do that again with the new clutch--unless you burn that one out too...
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Visionnn
Oct 3, 2015 05:16 AM
Learned Hand
Oct 1, 2015 09:02 AM
