oil levels/oil change with filter 5 qts
Old May 17, 2007 | 03:05 PM
uhohitzmikeo's Avatar
i was just wondering where everyones oil level was at and how many qts did u use?
i just changed mine today with mobil 1 synthetic with 5 qts and filter.
i waited about 30min after the car was off and checked and the oil level was on the H. the manual said it had to be between the L and H. do you think its fine?
Old May 17, 2007 | 03:12 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
5 quarts is what the G takes. I dont even check the level after i change it anymore because i know that with 5 quarts my dipstick is perfectly on the H mark.
-GP-
Old May 17, 2007 | 03:57 PM
Sac2904's Avatar
I think it's fine since you changed the oil filter too. I had mine done last week, same amount. You could check it again on early morning before you warm up the engine, you would get much better reading than just turn off your engine for 30mins!
Old May 17, 2007 | 05:29 PM
BadBoy06's Avatar
I'm just about 3/4 up after change and cold check
Old May 17, 2007 | 09:26 PM
TurboDreamzG's Avatar
Just did mine the other day as well....had the same deal you do. but its good cause 5 quarts is what my buddy puts in his.
Old May 17, 2007 | 09:50 PM
ttrank's Avatar
Grocery getter
I have to use 6.5qts because of the spacer and oil pan I have but after that with a filter it's just below the "H".
Old May 17, 2007 | 11:41 PM
Chrlesmd's Avatar
Yeah, you should be good. Just make sure you check it every now and then.
Old May 18, 2007 | 12:32 PM
FenixL1P's Avatar
IIRC, owner's manual states 5 quarts (or the metric equivalent of 4.78 liters), this is when you change out the filter too...
correct me if i'm wrong...
Old May 20, 2007 | 01:53 AM
Jeff92se's Avatar
Red Card Crew
Well as long as you made sure you emptied the oil completely, you are fine. It's actually good to know what 5qt actually looks like on the dipstick so you know when you are running low.
All cars a bit diff so that's why the manual puts the HUGE variance in there. I mean "inbetween L and H"? hehe. IMHO that's covering your butt a bit too much Infiniti.
Old May 20, 2007 | 02:21 AM
WhosRich's Avatar
how do you guys even get accurated readings?! everytime i try to check my oil, the darn dipstick rubs against the metal around it and messes up my readings..
Old May 20, 2007 | 04:06 AM
nate4598's Avatar
I put in 5.5 quarts everytime
Old May 20, 2007 | 04:11 AM
abcquackyxyz's Avatar
takes a lot of finesse and patience.. Or..you can get the 07 sedan and have the dipstick right in the middle of the engine
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
justgotg35
Jul 19, 2015 12:33 PM
