brake fluid COVER kit review
Old Mar 3, 2004 | 12:30 AM
  #46
RocketsRedGlare's Avatar
Re: brake fluid COVER review
Ordered my brake fluid cover and clear corners today. Why the heck didn't it come with this from the factory??????
Thanks for the great support.
p.s. 1202 miles. Gonna have fun on the way home from work tonight!!!
On-On
S&S
Old Mar 4, 2004 | 06:11 AM
  #47
ryoken's Avatar
Don't know why it didn't come with the cover, but I can tell you why it didn't come with clear corners.
They're not street legal.
Old Mar 4, 2004 | 06:29 PM
  #48
Got my brake fluid cover in today (3 days!!!). Install went easy, I cut about 1/16" off the front lip with a razor. The cover was sitting on the rubber grommets where the brake line and some wires go through. Mine must sit hifgher than others.
Still looking at the clear corners though. Seems like they don't fit.
On-On
S&S
Old Mar 11, 2004 | 08:11 AM
  #49
Tfasano's Avatar
Has anyone found this for a better price than strictlyz?
Luv My G
Old Mar 11, 2004 | 11:38 AM
  #50
ryoken's Avatar
StrictlyZ is the only place I know of that's doing this. It's a custom kit that they put together.
Old Mar 11, 2004 | 11:17 PM
  #51
RashMan1450's Avatar
Yea, it will cost your a lilttle but less to buy it from japanparts.com. But to have it installed you have to take it to a bodyshop. Reason is you have to chave to metal off the car.. Well it will take you over the 150 dollar barrier.
Strictly Z is the way to go.
2004 Diamond Graphite G35 Coupe 6MT, Premium Package, Aero Package, DVD Nav
2003 Brilliant Silver G35 Sedan Premium Package, Aero Package, DVD Nav
Old May 18, 2004 | 08:46 AM
  #52
SixFive's Avatar
Is there any chance the brake fluid cover helps keep the hvac air cooler by closing off the hot air sucked into the firewall side (behind the compartment that the cover covers)???
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Injen CAI
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk ex-3500 Tweeter Upgrade/Shock Sensor/H-Liner Under Hood
Old May 19, 2004 | 03:36 AM
  #53
locns's Avatar
Recently, I ordered the driver's side battery (brake fluid) cover from StrictlyZ. Unfortunately, when my order arrived, it did not come with installation instructions.
After reviewing this thread, I think I've figured out where the various parts go in terms of installation; however, upon closing the hood of the car, I noticed that it's not flush with the frame/body of the car. Fearing damage to the car, I've removed the brake fluid cover.
As I am without official installation instructions, does anyone have a copy that I can refer to in order to properly install the driver’s side battery cover? Any help is appreciated.
Old May 19, 2004 | 05:55 AM
  #54
skaline's Avatar
here ya go
Old May 19, 2004 | 05:56 AM
  #55
skaline's Avatar
page 1
Old May 19, 2004 | 05:57 AM
  #56
skaline's Avatar
page 2
Old May 19, 2004 | 11:39 AM
  #57
locns's Avatar
Thank you very much, skaline!
The instructions helped. Attached is an image of the brake fluid cover installed. It took a little elbow grease, but the hood closes flush with the car frame/body now.
Can you confirm that my installation of the rubber/weather stripping is correct? I have it going over the plastic edge rather than the metal edge. If I want it to install over the metal edge, I'll have to make a small cut in the stripping near the A/C tubing where the gap between the metal and plastic edges begins to appear.
Old May 19, 2004 | 04:08 PM
  #58
skaline's Avatar
Looks like your cover is sitting just a little bit higher compared to the metal edge. It should actually be lower than the metal edge. Make sure the weather stripping along the top edge of the cover isn't preventing you from seating the cover all the way down. Then the weather stipping should cover BOTH the plastic and metal edges all the way up. You shouldn't have to cut it. Just push it on. It will fit.
Attached Thumbnails brake fluid COVER kit review-batt-inst-pp1a.jpg   brake fluid COVER kit review-batt-inst-pp2a.jpg
Old May 19, 2004 | 04:30 PM
  #59
skaline's Avatar
6-5, I kinda doubt the cover does very much to keep the hvac air cooler but there was a post a while back where someone insulated the lines to make the ac colder and to prevent sweating/dripping. ac line mod
Old May 20, 2004 | 05:48 AM
  #60
locns's Avatar
Thank you for the clarification, skaline. Initially, this is what I thought, too; it looks like the cover I received might need some additional customizing. I'm unable to get the weather stripping to cover BOTH the plastic and metal edges all the way up. This is because of a gap that is produced by a spacer next to the plastic edge; it widens near the top. I might have to shave some of the spacer plastic down in order to reduce the gap between the metal and plastic edges.
Appreciate all the help. Great support community here.
