Fuel Filter?
Old Nov 17, 2007 | 04:50 PM
bluestacy04's Avatar
Fuel Filter?
When do we need to replace it? I looked in the manuel and it doesn't say anything about it. Normally you change them every 36k.
Old Nov 17, 2007 | 05:47 PM
superchargedg's Avatar
Our car,s do not have a conventional servicable fuel filter.I is a strainer in the tank and does not require service.
Old Nov 17, 2007 | 08:07 PM
thanks for the info thats what i was wandering!
Old Nov 18, 2007 | 09:40 AM
sloppymax's Avatar
my last nissan vehicle had the fuel filter in the same location in the tank. at 50k miles it was caked with sediment and i only used top tier 93 octane. the filter is a cartridge attached to the fuel pump assembly and can be change. it is also just like every other fuel filter made, it gets dirty and clogged over time. the filter along with a new o ring ran me about 25 shipped for my previous VQ but i have not priced it yet on this car.
this is another item that nissan/infiniti can claim that does not need service so it looks like their maintenance costs are low but any enthusiast knows keeping your plugs in for 100k miles is not a smart idea either especially if you are changing them yourself.
Old Nov 18, 2007 | 05:25 PM
Gordgee's Avatar
Administrator
How difficult is it to change the filter? Is it from underneath the car, or would you have to remove the back seat or something?
Old Nov 18, 2007 | 07:37 PM
fortified's Avatar
When it comes to adding fuel, octane level has nothing to do with cleanliness.
Stations with a greater turnover generally have cleaner tanks. Assuming they keep their filters changed.
Top tier is for gas meeting minimum standards for cleaning out deposits, and has nothing to do with the cleanliness of the gas in underground tanks.
Old Nov 18, 2007 | 08:27 PM
sloppymax's Avatar
Remove the bench in the back seat. There was only 1 access port in my other VQ but I think this vehicle has 2. You undo the port which was 3 bolts and pull the o ring out then pull the fuel pump assembly out. The filter is just a cartridge that is attached to the assembly. Replace then reverse the process. I would highly suggest getting a new o ring with the new filter as the old one can be very difficult to seal back up. Also I should have mentioned in my previous statement that the top tier station I visit has a high volume of traffic here in Charlotte. I also never put gas in if I see the truck filling the pumps as it has a tendency to stir up the junk.
Old Nov 18, 2007 | 09:55 PM
Gordgee's Avatar
Administrator
Thanks. I'll probably replace mine next spring.
I try never filling up when the tanker's there for that very reason. Some ppl think it's good because the gas is 'fresher'.
Old Nov 19, 2007 | 07:31 AM
sloppymax's Avatar
This is just popped in my head. Make sure you have less than 1/4 of a tank or retrieving the assembly would prove to be difficult and messy. That is what the ESM for my old VQ recommended.
Old Nov 19, 2007 | 06:19 PM
I pulled the fuel pump out twice...when i went stage 4 on the stillen setup at about 7800 miles and at 45,000 miles when i put the greddy twins on and my strainer was spotless.I dont know what kind of gas you get but it must be crappy.
Old Nov 19, 2007 | 08:34 PM
sloppymax's Avatar
i mentioned what type of gas. if you are looking for a brand then i attempt to use Shell. the only difference in that car was it was on a return system which i eventually converted to a returnless via an fpr. that could very well influence it as i did not check the filter after the returnless setup. i will still pull mine at around 40-50k to check it as this fuel filter is not magic and gets dirty just like every other fuel filter produced is intended to do.
Old Nov 21, 2007 | 12:00 AM
OCG35's Avatar
Thumbs up Tips on Pumping Gas
Here are some thigs to consider at the pump... this is from an industry newsletter that was forwarded to me:
Tips on Pumping Gas
With the price of gasoline once again going up as we enter the Holiday Season, here's a few good tips for you to remember; every bit helps as we try to monitor our gasoline consumption. The writer is a 31 year veteran of the petroleum industry and he shares some of his expertise. The content has been edited.
"I don't know what you are paying for gasoline but I'm sure that you are quite concerned each time you have to fill up the tank. I have worked in the petroleum industry for over thirty years now, so here are some simple tips for you to get more of your money's worth for every gallon that you pay at the pump.
My experience is based on one of the largest fuel pipeline companies in the west coast. Our facility delivers about 4 million gallons in a 24-hour period through the pipeline. We move a variety of different fuels, and they include diesel, jet fuel, and gasoline; both regular and premium grades. We also maintain many storage tanks with a total capacity of nearly 20 million gallons to hold these various petroleum products.
Tip #1
Only buy or fill up your vehicle in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground, the more dense the gasoline. As the temperature increases, gasoline expands, so buying in the afternoon or in the evening means that your gallon that you pay for may not be exactly a gallon. One of the key aspects in the petroleum business, relates to the specific gravity and the temperature of the petroleum products, plays an important role.
Just a one-degree rise in temperature is a significant factor or swing for this business. Remember, while our facilities have temperature compensated pumps, you can bet your local service station does not!
Tip #2
When you're filling up do not squeeze the trigger of the nozzle in the fast mode. Next time you are at the pump, you will see that the trigger has three (3) stages: low, middle, and high. You should be pumping on the "low speed," thereby minimizing the vapors that are created while you are pumping. The faster you pump your gas, the more vapors you are creating. All hoses at the pump have a vapor return. If you are pumping at a faster rate, some of the liquid that goes to your tank becomes vapor. As you maintain a tight seal with the nozzle and gas tank, those vapors are being sucked up and backed into the underground storage tank so you're getting less volume for your money. On a related note, most people are aware about the tremendous waste in "topping off" the tank, as fuel is once again, returned to the underground storage tanks.
Tip #3
One of the most important tips is to fill up when your gas tank is about 50% full. The reason for this is, the more gas you have in your tank the less oxygen is occupying space in the gas tank. Gasoline evaporates extremely fast; much faster than most people realize. To minimize this loss, commercial gasoline storage tanks have an internal floating or moving ceiling or roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation.
Tip #4
This is an important tip which will help keep your fuel system in your vehicle as clean and efficient as possible. If there is a gasoline tanker truck pumping into the underground storage tank when you arrive to buy gas, it's probably a good idea to move on and find another station. As any mass distributed product, there are certain by-products. The gasoline being delivered is most likely stirring up the some of the sediment and dirt that is typically on the bottom of the storage tank. Some of this material may be picked up by the pump and inadvertently delivered into your vehicle.
Our commercial facility takes into account each of these guidelines as they are important to our business. We also ensure that the time of delivery, every truck we load is temperature compensated so every gallon is actually the exact amount. We hope these simple tips will help you get the most value for your money.
Do share these tips with others!
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
Hogbone
Sep 28, 2015 06:44 PM
vamarris
Sep 26, 2015 12:56 PM
