advancing your timing by 3 degrees
Old May 3, 2008 | 07:50 PM
  #31
Nismo G's Avatar
Originally Posted by StreetChase
my timing is advanced 2 degrees. I wouldnt go anymore than that
+1. I wouldn't go anymore than 2 degrees. I advanced mine 2 degrees and didn't really notice a whole lot. I haven't been to the track either.
-Sean
Old May 4, 2008 | 11:09 AM
  #32
Hydrazine's Avatar
I tested this on the dyno. It was a comparison of -2' and +2'. It didn't do anything unless 95+ octane gas was used.
The timing advance only advances the limit the ECU will allow. It doesn't necessarily (directly) advance the timing itself.
On 91 octane California dirt gasoline, the knock sensors are already limiting the timing up to a point. You can advance the ECU timing all day long but it won't do anything unless the gasoline will prevent knock.
If you have good gas in your area, it can make a difference.
Be happy if you don't live in Ca.
Old May 4, 2008 | 11:12 AM
  #33
Nismo G's Avatar
We have 93 octane here in florida? Think i would see anything? Like i posted before i really didn't feel anything.
-Sean
Old May 4, 2008 | 05:13 PM
  #34
_jb's Avatar
_jb
Photographer
+1
You can use a Consult-2 or UpRev's Cipher to bump the timing up to two degrees. As Tony said, it is not a magical increase in horsepower.
I tried it on my G35 Coupe with 93 octane while it was attached to a dyno and it did not make any difference. I drove my car with it and without it and it did not make any difference.
Getting a tune using Osiris made a difference.
Getting a Haltech and having it tuned on a dyno made a difference.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
wojowojo16
Jul 27, 2015 09:57 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
