Serpentine belt replacement
Originally Posted by lexusk8
I changed both the A/C and power steering drive belts at 45K miles. You'll know they most likely need to be changed when you hear a squealing in the belt area after engine start-up (which gradually goes away after a couple min warm-up time).
Originally Posted by jander04
The AC belt broke on my 2003 G35 at about 92,000 miles. I bought the car used, so I have no idea if the belt was a factory belt. I suspect it was.
![EEK!](https://g35driver.com/forums/images/smilies/eek.gif)
Originally Posted by blownvert
ok i got a longgg way to go then! Use it until it breaks then the car will sieze up me going on the highway.
What would honestly happen if your belt broke while driving?
Really they're only about $30 for both. I got mine from Riverside Infiniti. There's even a DIY somewhere on here. I think the dealership wanted something like $200 to replace both. It's one of those jobs that requires more time to get ready for it than actually replacing them.
Originally Posted by keen1801
Anything being driven by the belt will stop working. It's not worth waiting until the belt snaps on you on the freeway. Taking a turn going 80mph with no powersteering on the freeway is no fun. Ask me how I know.
well i do not think i can do it myself, no jack or stands. Wow $200 from dealership. Can i go anywhere like monroe? Do i need OEM belts?
https://g35driver.com/forums/engine-drivetrain-forced-induction-diy/117355-diy-power-steering-alternator-air-conditioning-belt-change.html
Here's the DIY for the coupes that I used. Basically the same for the sedan. It takes about 30-45 minutes as lexusk8 said.
