service engine soon..
Old Jul 30, 2008 | 06:29 PM
jayflyxx's Avatar
wuts up guys? i have a 2005 G35x. it has 68k miles, yah i drive alot. but last thursday. my service engine soon light came on with slip and awd lights. they went off except the service light which is still on. i went to autozone and they gave me the code p2135 which is throttle position sensor. the dealer said it was prolly the gas cap, or i fill with the car on which i did. the car drives fine but the light is still on, do i need to get the TPS which isn't sold seperately or will the light go off.. its been 140 miles already.. thanks and sorry for the long post. and i did search!! with no help...
Old Jul 30, 2008 | 06:44 PM
Ghayes23's Avatar
I'm having the same issue right now. You probably need to replace the sensor. Here's a link to what people said about mine on my350z:
http://my350z.com/forum/maintenance-...need-help.html
Hope that helps.
Old Jul 31, 2008 | 07:30 PM
GF-4D-G35's Avatar
Is that sensor in the throttle body? If so there is a way to do a reset. Check out MotorDyne's site, they have instructions at the end of their plenum install instructions.
Old Aug 1, 2008 | 02:26 AM
Tollboothwilley's Avatar
I'd do a throttle position reset, and then do the ECU reset.
Should fix everything.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
poker_lamina
Sep 1, 2015 09:04 AM
03sedang35
Aug 29, 2015 07:56 PM
Ivan Duben
Canada
Aug 29, 2015 12:50 AM
igking
Jul 19, 2015 01:12 AM
