AFTERMARKET INTAKE OWNERS---READ ASAP
Old May 5, 2004 | 08:58 PM
SC8's Avatar
SC8
Re: AFTERMARKET INTAKE OWNERS---READ ASAP
is dat wit injen intakes too?
Old May 5, 2004 | 09:20 PM
GeoBau's Avatar
Cactus Hugging Admin
Excellent post-- many thanks,
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
Old May 5, 2004 | 10:00 PM
Chops1's Avatar
I got the injen and mine was touching, so I used a zip tie on the a/c line and pulled it away.
chops's Avatar
Old May 5, 2004 | 10:01 PM
iLLG35's Avatar
NY G-Squad G Race Driver
OMGGGGGGGGGGGGGGG, is that why my AC DOESNT WORK!?!?!?!?!??!?!?! I was wondering why in the hell my AC wouldnt be working on a brand new car wow...... Now im happier but pissed, is this expensive?? Its also a leased car so i think im pretty screwed, suggestions? help? Thanks iLLG
Martin
2003.5 BS G35
Full Aero/Sport Package
Injen CAI
350Z Springs
Clear Corners
ADR M-Classic 19's Soon..
Old May 5, 2004 | 10:23 PM
Xman's Avatar
WOW! Thanks for the heads up!
2K4 G35x/Brilliant Silver/Graphite/Premium/Wood
Stillen Hi-Flow/ Z tube/ Ground Kit
Coming soon...Crawford v5
Old May 5, 2004 | 10:53 PM
Chops1's Avatar
ill, put the stock air box back on an carry it in, I read somewhere that the dealership quoted $700 for the fix. I dunno?????
Chops
chops's Avatar
Chops
Old May 5, 2004 | 11:12 PM
Aznteazer's Avatar
wouldn't they know you had an intake by looking at your ac line?
Old May 5, 2004 | 11:44 PM
iLLG35's Avatar
Oh man, i think I have a good fix though as mentioned by Dabomb. Ill get some rubber or plastic tubing to cover the AC line for the remainer of my lease (2 years) and to stop the rubbing. And now it would be useless since theres still a leak, I think I could patch the leak with some liquid metal patcher or welder then get the ac coolant refilled or "recharged". Does anyone think it will work? Martin
Martin
2003.5 BS G35
Injen CAI
350Z Springs
Clear Corners
Old May 5, 2004 | 11:46 PM
phat911's Avatar
Dude,
Great catch! I followed your instructions and I was able to a !/4 inch gap between the MAF and the a/c line by also putting a spacer on the 350Z tube. Take the intake tube loose at the throttle plate, remove the bolt on the intake tube bracket (it bolts on to the plenum) add 1/2 to 3/4 inch spacer (iused some old nuts) this will raise the intake tube enough to clear the a/c line. I didn't modify the air cleaner bracket, but I did put a spacer in the same place that you did. You will need to put a longer bolt on the intake bracket. and remember to retighten the the intake tube at the throttle plate. I'll be keeping an eye on this modification through tomorrow, if it works out, I'll make spacers out of aluminum or palstic (depends on what I find at Home Depot. If anyone is interested, I'll post the sizes tomorrow. Again, great catch Dabomb!
Old May 6, 2004 | 12:49 AM
dabomb's Avatar
FGC Central Florida BOD
<hr></blockquote>
ITS DEFINATLY WITH BOTH INJEN AND JWT...id be willing to guess all other CAIs have similar problem just because of where the A/C line is.
Im gonna work on it tomorrow to try and improve it even more. Add the spacer for the Ztube bracket and tape the tubing down more. Id assume if u dont tape the tubing down that this can also cause a rub...better safe than sorry
As for fixing leaks that have already been created...Infiniti quotes as much as $800...
'03 G35 Coupe | Black on Black | Performance
20% tint | Clear Corners | Ztube & Popcharger
http://www.cardomain.com/id/dabomb3
Old May 6, 2004 | 06:53 AM
Catatafish's Avatar
After checking mine again, after 3 days with the bracket bent and the spacer, the A/C line crept back. I used a zip tie to hold the A/C line back further, and time will tell if it can withstand the heat. The A/C line gets pretty hot under there.
2004.5 Coupe/5AT/Ivory/Everything but chin spoiler/Z Tube-Popcharger/Crawford V5 Plenum on the way
Old May 6, 2004 | 07:03 AM
Xman's Avatar
It's there with the Stillen Hi-flow/Z tube setup too. Checked last night after reading this. Thanks again. Trip to Home Depot!
Old May 6, 2004 | 09:04 AM
dabomb's Avatar
I found this thread...he used a foam piping to keep the A/C line colder but maybe this would be better as It wouldnt cause any rub itself
https://g35driver.com/forums/showfla...&sb=5&part=all
