Car burning alot of oil
Old Aug 13, 2008 | 10:41 AM
ONEmike's Avatar
so i did an oil change about 2 weeks ago to find that i only have about 2 quarts. i do my oil changes every 5000km and when i do them there is so little left over.
i put in about 5 quarts and 5000km later i have 2 quarts left if that normal?
Old Aug 13, 2008 | 10:50 AM
Yv12345vY's Avatar
Not normal. Take it to the dealer, start an oil consumption test. Use the search button above too, there are plenty of threads about this.
Old Aug 14, 2008 | 10:28 AM
Q45tech's Avatar
Until it is PROVEN that the engine is defective by consumming oil your warranty requires that you maintain oil level full.
Running engine low of oil [even 1 quart] has damaged your crank and rod bearings. Your negligence in dealing with oil consumption has now created other problems.
Hopefully you have written legal proof that oil changes were done on time and mileage. Not just purchase receipts for oil/filters.
Old Aug 14, 2008 | 03:13 PM
G37Rider92649's Avatar
Oil consumption issue, take it back to the dealer, if you're under warranty and this is the case you'll get a new motor. Good luck
Old Sep 19, 2008 | 09:01 PM
cutiewolf's Avatar
sorry to hijack ur post..
wat if im out of warranty? whats the best thing i can do?
Old Sep 20, 2008 | 02:37 PM
Q45tech's Avatar
Your choice between rebuilding engine [rings and bearings] or buying a replacement engine OR buying oil by the case and adding a quart every 1,000 miles or less until the cats clog from all the oil.
Assuming you don't just have leaks?
Old Sep 22, 2008 | 08:33 PM
geronimomoe's Avatar
Well, some manufacturers state that burning 1 quart per 1000 miles (1600 km) is within "acceptable" limits, cost of rebuilding a motor vs cost of oil/catalytic converter, etc. Since 5000 KM = 3125 Miles, you're pretty close to that 1 quart/1000 mile limit.
However, for me anything more than 1/2 qt of oil burned every 3000 miles is NOT acceptable. Between my parents cars (9 cars in 30 years) and my cars (7 cars in 24 years), no car we've owned has ever burned more than 1/2 quart every 5000 miles.
I'd complain loudly.
Old Sep 22, 2008 | 11:01 PM
PTownG's Avatar
Changing oil every 5k is not negligence. With modern oils that is fully acceptable. These cars have known excessive consumption. Do you work for infiniti?
Old Sep 23, 2008 | 12:27 AM
Canadian's Avatar
Canada, eh?
Why post wrong information? If the engine is CONSUMING OIL he is not obligated to make sure he keeps it topped off everyday. He is entitled to a new engine!! - that is if he is under warranty.
If you haven't already, take it to the dealer. They will do an oil consumption test and determine if you're in need of a new motor.
ghost_g35
Aug 7, 2015 10:31 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
mjfenix
Jul 17, 2015 02:07 PM
