Check this before your powertrain warranty is up!
Old Jun 4, 2009 | 10:57 PM
  #151
lophix's Avatar
Chit. Almost wished I didn't find this thread, but glad I did. Just got an 05 FX35 for my wife 3weeks ago with 37k and picked up an 05 Sedan 5MT yesterday and it turned 60k as i drove it back home from texas. I'll check both on saturday and if I see any oil, I'll take a day off work to go down to the infiniti dealer (85miles away) to get it done. Just to re-affirm: the powertrain warranties are for 6 years, 72,000 miles on both vehicles?
Old Jun 5, 2009 | 08:05 AM
  #152
lexusk8's Avatar
^ Powertrain warranty for any Infiniti is 6 years or 70K miles, whichever comes first.
Old Jun 9, 2009 | 01:58 PM
  #153
mr_ecktid's Avatar
had it checked today at 152k miles, sure enough the shop said there was oil in the tubes they could see where they didn't have to open up the intake plenum.
was quoted $500ish for new valve cover, gasket seals, gasket covers and whatever else they said was needed to fix it.
Old Jun 21, 2009 | 11:46 PM
  #154
thescreensavers's Avatar
Mr.202?
So I have the Infiniti Pre Certified 100k warranty.
For engine it says it covers. Cylinder heads, block and all internal parts, rocker covers and oil pan, valve train and front cover, Timing chain and tensioner, oil pump, water pump and fuel pump, fuel injectors, intake and exhaust manifolds,flywheel,seals and gaskets.
I not exactly sure what this is listed under but is this problem covered under my warranty? I will take it in some time when I hit 60k.
Thanks
Old Jun 22, 2009 | 05:29 AM
  #155
INDYMAC's Avatar
Just plan on changing your plugs before your warranty expires. That way they can replace the valve covers while their changing the plugs.
Old Jun 22, 2009 | 11:22 AM
  #156
bert039's Avatar
So I was on the Z boards and found that a couple guys are put RTV around the faulty seals to keep it from leaking. I didn't go that route, but just something to consider.
Old Jun 22, 2009 | 02:52 PM
  #157
jimNC's Avatar
I'm not going to go that route either, but do you happen to have a link? I'm curious how that would work out over time, I'd be concerned it would not last long under the heat. I'd also hate to have to keep pulling plugs to keep checking on it.
Old Jun 23, 2009 | 02:02 AM
  #158
bert039's Avatar
Check in:
http://my350z.com/forum/maintenance-...plug-help.html
It's not too much info though.
Old Jul 23, 2009 | 09:38 PM
  #159
rapidrob's Avatar
synthetic oil a problem?
I bought a 2003 with 82k mi a couple of months ago. At 84k I switched it over to mobil one. At 85k I changed the plugs and found oil in two of the tubes (closest to driver and passenger). 500 miles later I have an oil leak under car and upon inspection appears to be leaking from the actual valve cover gasket on the drivers side. I was wondering if swithing over to synthetic oil at this milage may have contributed to the problem. Any thoughts?
Old Jul 26, 2009 | 12:49 AM
  #160
vincentl's Avatar
Just changed my plugs at 60k and found oil in all three left side plugs.
Attached Thumbnails Check this before your powertrain warranty is up!-oilpool.jpg
Old Aug 8, 2009 | 04:13 PM
  #161
mesias's Avatar
I just check plugs 3, 4, 5 and 6... clean and shiny! No signs of oil at all! I don't know if I should be happy or worried since the car only have 5 months left of powertrain warranty with only 52K miles.
Old Aug 19, 2009 | 03:38 PM
  #162
KingoftheRoad1's Avatar
Just came across the oil leak problem. I did not read all the pages in this thread. I know a thing or two about cars. Normally this is a simple tightening or replace the gasket. Why is it necessary to replace the whole valve cover? And why is the valve cover so expensive?
Old Aug 21, 2009 | 12:44 AM
  #163
canucklehead's Avatar
thank you g35driver.com! i just checked my spark plug tubes and two of them were dripping with oil. it looks like i'll be paying another visit to my local dealer for some more warranty work! that's the only time they see me.
does anyone know if the spark plugs are replaced under warranty along with the covers etc?
Old Aug 21, 2009 | 07:38 AM
  #164
jimNC's Avatar
Because for some reason the spark plug gaskets are molded into the valve covers and no one can give me a good reason (heh, or ANY reason) why that's done. So it all comes down to $$$. It always does when something doesn't make sense.
Old Aug 30, 2009 | 11:26 PM
  #165
Easy Tiger's Avatar
Hi all,
I am from Australia and am new to this forum. I have a 2001 Nissan Skyline V35 250GT which is a 2.5 litre version of your G35 sedan.
I was searching these forums and found this problem, so I had my spark plugs changed and I had oil pooling in mine too. I had the problem fixed, but was able to find the parts for the V35 to only replace the rocker cover valve seals and not the whole piece. Don't know if it might help any of you that are out of warranty, but maybe have a look around, you might get out of it a bit cheaper.
