Check this before your powertrain warranty is up!
Old Oct 11, 2009 | 10:30 PM
  #181
r1forever80's Avatar
I just checked my plugs. I believe #6 plug had oil pooling and #1 plug seemed to have oil at valve cover. My car had a date of 03/04 and has 59k. I should still be under warranty?
Old Oct 21, 2009 | 03:14 PM
  #182
V35MI's Avatar
same boat unfortunately for me too. I'm only at 37k but it's an 05. I'm not sure of the manufacture date, but I'm also not around my manual to check the powertrain warranty. it was down a quart of oil at the last change too, i suppose i'll knock two birds out with one stone when i visit the dealer soon.
Old Oct 22, 2009 | 09:54 AM
  #183
iamericgee's Avatar
im doing mine this weekend and i have about 76000 miles so hopefully there is no spooling going on there
Old Oct 30, 2009 | 10:57 PM
  #184
update. When i took my car in i also had them check for a little knock the engine was making. They have had my car for 3 wks now. They are replacing the long block under warranty. I want to say it was a lifter sticking but they dont know for sure. Looks like im good for a few more miles now. Also the service manager said they dont replace the valve covers to fix the pooling but just the gaskets. We will see when i pick it up
Old Oct 30, 2009 | 11:08 PM
  #185
G35fromTO's Avatar
Did you have the CEL on/codes?
Old Oct 30, 2009 | 11:14 PM
  #186
thescreensavers's Avatar
Mr.202?
I thought there was no way to do this and you have to replace the whole thing.
At least that's what I read if I remember correctly.
Old Oct 30, 2009 | 11:34 PM
  #187
Kouki Al's Avatar
FYI VQ's and a lot of Nissans use Shim over bucket system. No lifters there.
Old Oct 30, 2009 | 11:39 PM
  #188
Yea i dont know too much bout todays engines. I just stick with paint and body.
I I thought there was no way to do this and you have to replace the whole thing.
told them that i read that they couldnt change the gaskets but had to replace the covers so i thought but the sevice manager said they could change them. He said it was a gasket kit that had 3 gaskets plus the valve cover gasket. So we will see. I have a few more months and another 10k miles to go on warranty so ill deff check before its up.
Old Oct 30, 2009 | 11:44 PM
  #189
Kouki Al's Avatar
Just wanted to point it out, not busting your ***** or anything.
Old Oct 30, 2009 | 11:48 PM
  #190
no probs. Unless your a girl your not gettin anywhere near my *****. Ill just be glad to get my car back. I got an 08 as a loaner but since im out of town most wks i havent had a chance to play with it. When i did that sucker is pretty peppy.
Old Oct 31, 2009 | 11:04 PM
  #191
Picked up car today. Paper work says the oil pump failed which cause the scoring of the camshaft lobes from the lack of oil pressure. All i can say is i got a new long block for nothing. Am very pleased. They didnt replace the valve cover gaskets because it came with new ones.
Old Nov 15, 2009 | 01:00 AM
  #192
lox1985's Avatar
Well, I just found some oil in cylinder 6 when changing my plugs. I already had an appointment for oil consumption next tuesday and I will also have them check it out. I got 05 g35 with 45k miles
Old Nov 20, 2009 | 10:54 PM
  #193
crazypatty's Avatar
Valve cover oil leak
Hello, this is my first post here! Proud new owner of 2005 G35x 65,000 miles. I also pulled my number six coil pack today and low and behold OIL. I already have an appointment for next week. Thank god you guys are here posting otherwise I never would have checked this!
Should we be stirring up some dust at Infiniti as to why a better design/ produced valve cover is not available, and could this be headed towards a recall (I know someone mentioned that already)? Who is to say that these valve covers do not start leaking right from the factory? And are mine going to slowly start leaking again after they put on the new valve covers so they can "patch" this problem till my powertrain warranty is up? Thanks guys!!!
Old Nov 21, 2009 | 04:53 AM
  #194
lox1985's Avatar
We probably should say something, but those issues are reported to them anyways when you get serviced for it. Even though, they fixed it (according to them). I'm going to check again after a 1000 miles or so. To make sure.
Old Dec 2, 2009 | 07:41 PM
  #195
Mustang5L5's Avatar
So the new VC is just the same as the old one? No improvments made?
So we could have to replace these covers more than once on a car? Has anyone had to do that yet?
Maybe this Sat, i'll finally get around to checking my plugs for oil pooling.
