surge performance chip?
Old Jan 9, 2010 | 11:33 AM
  #121
liche's Avatar
Originally Posted by OCG35
I still haven't seen anyone (or heard from a source I consider reliable) successfully cutting MAF sensor wires on a G35.
Is this guy for real, or is he just putting us on?
This guy has just got be responding like this in jest. Nobody can be that dense.
Plus its REALLY FUNNY how the only bit of information this guy brings up on the subject was a quote copied from a user named BIKINILUST!
Now thats golden!
I think its time for HAM SALAD to consult the wisest person in the universe - Augie Ben Doggie!
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/rL0wutsciS8&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/rL0wutsciS8&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Jan 9, 2010 | 12:13 PM
  #122
OCG35's Avatar
^^^ I posted 8 different ppl saying dont cut it dumb @ss...
where do you get the idea it was only bikinilust?
the bottom line is there are two of you saying you can cut it (even though neither of you have - and neither can reference anyone that has)... yet there are many that say "do not"
this fact will never change.
Old Jan 9, 2010 | 12:14 PM
  #123
InShAllAh's Avatar
@ liche LMFAO.... Classic
Old Jan 9, 2010 | 03:09 PM
  #124
Jeff92se's Avatar
Red Card Crew
Mike, toll has plain as day said he cut it. Unless you are blind.
*Jeff notes that the maxima guys, JWT and UTEC all have instructions on how to either cut or extend ecu wires which guess what, includes the maf sensor wire.*
Old Jan 9, 2010 | 04:20 PM
  #125
OCG35's Avatar
yeah, yeah, you and liche are right and all the others are wrong (8 of which I posted - many others besides that)...
whatever makes you feel better...
(I just wish I could see you do it to your car so I can laugh my @ss off when it doesnt run right)...
Old Jan 9, 2010 | 04:24 PM
  #126
InShAllAh's Avatar
^ Ha, y'all broke him down! LOL ....J/K OC I don't want you to start drama w/ me about how you were not OWNED by liche and jeff... LOL
Old Jan 9, 2010 | 04:27 PM
  #127
OCG35's Avatar
^^^ did you really want to see the same **** rehashed for another 10 pages?... just re-read that last 10, it wont ever change...
Old Jan 9, 2010 | 07:30 PM
  #128
Jeff92se's Avatar
Red Card Crew
Toll cut his wires and what? Does his car run yes or no?
Old Jan 10, 2010 | 06:32 AM
  #129
InShAllAh's Avatar
^ lol
Old Jan 10, 2010 | 03:28 PM
  #130
OCG35's Avatar
John, does your aftermarket EMS read your MAF signal? Or does your stock ECU read it?
Old Jan 10, 2010 | 03:33 PM
  #131
Tollboothwilley's Avatar
I cut up my ECU wires with the battery off. Let me double check but I believe the wires I cut WERE NOT related to the MAF but instead were power, ground, throttle body, and injectors.
But all things aside, there isn't any difference between the MAF wires and the ignition, injectors, power, ground and throttle body wires.
Old Jan 10, 2010 | 03:53 PM
  #132
OCG35's Avatar
for sake of argument, it would be great if you could check
Thanks ~
Old Jan 10, 2010 | 04:04 PM
  #133
I just checked. I did also cut the MAF sensor wire at the ECU as the Emanage does not just tap but actually intercepts the MAF signal so it can adjust as necessary.
Old Jan 10, 2010 | 04:43 PM
  #134
OCG35's Avatar
^^^ that's what I suspected... thanks for checking.
Jeff - it should go without saying... but the reference is to normal use - with ECU reading the signal.
People have had problems and others have learned for their problem experience and advise not to cut them. It really is that simple - and your & linche haven't done a thing to make anyone with reasonable sense confident enough to cut their MAF wires (to the stock ECU).
Having that been said - I'm also referring to cutting at the sensor end - not the ECU end (for whatever thats worth) - but I stated that already earlier in this thread.
This could have ended here https://g35driver.com/forums/4800886-post125.html
or here https://g35driver.com/forums/4802221-post130.html but then you'd have nothing to do with your life now would you...
Old Jan 10, 2010 | 05:01 PM
  #135
InShAllAh's Avatar
^WOW .... he's still going...
