Custom 3.5" (90mm) CAI in the works
Old Nov 17, 2008 | 03:13 PM
Andrei's Avatar
This is also going to be part of the future intake for a custom single turbo kit and I have a long way to go before I can even start to piece that together and weld it. But good things come to those who wait.
I also just broke the the MAF when I got it out the car a few min ago so I need to buy another I had it in the car because I went by a shop to make an adapter for it but the aluminum plate I had was too thin to weld. My insurance expires next month on the 6th and I'll be saving $200 month by switching. So even if I broke the MAF that will make up for it x3.
How I broke the MAF housing.
Old Nov 17, 2008 | 03:26 PM
Boston's Avatar
So you need a new MAF sensor housing?
Old Nov 17, 2008 | 03:30 PM
Andrei's Avatar
Yes . Very sad too because that one was in mint condition and it wasn't heat baked dried up plastic.
Old Nov 17, 2008 | 03:33 PM
Boston's Avatar
I have an extra one for sale. Not sure if it's heat baked or not, just an OEM housing.
https://g35driver.com/forums/engine-...r-housing.html
Old Nov 17, 2008 | 03:35 PM
Andrei's Avatar
The OEM housing is 2.75" or smaller. The housing I broke is 90mm 3.5" and it came off a V8 Q45
Old Nov 17, 2008 | 03:36 PM
Boston's Avatar
Ah, I understand now.
Old Nov 17, 2008 | 06:47 PM
GTM's Avatar
GTM
You know you can't just put a bigger MAF in the car, it needs to be re-scaled for that MAF.
Old Nov 17, 2008 | 10:42 PM
Andrei's Avatar
I'll put in the sensor from my OEM housing in the 3.5" one. Should work.
Old Nov 18, 2008 | 09:29 AM
GreenGoblin's Avatar
The goblin resurrection
not to rain on your parade but there are guys making big power on stock intake platforms... This is not a weak link compared to other areas.
Old Nov 19, 2008 | 01:48 AM
dspiel's Avatar
seems overkill imo
Old Nov 19, 2008 | 01:58 AM
officerdbag's Avatar
whats that filter thing?? like that metal mesh?? air flow restriction?
Old Nov 19, 2008 | 03:07 AM
Andrei's Avatar
That's an AEM dryflow filter.
The IC will also have a 3.5" inlet and outlet. Custom.
Old Nov 25, 2008 | 02:55 PM
Andrei's Avatar
I dumped the MAF housing and went to a MAF flange for the sensor. Much more simple.
Old Nov 25, 2008 | 04:56 PM
_jb's Avatar
_jb
Photographer
Great job designing and machining that adapter plate.
I don't understand what you're trying to do with it though. If you decided not to use the larger MAF housing, why do you need an adapter?
It looks like you're trying to space a larger MAF sensor out so that it is centered on a smaller tube. I just can't figure out why you would want to do that. Maybe you can program/reprogram that voltage range easier in this MAF sensor?
I guess you're opposed to MAP mode?
Old Nov 25, 2008 | 05:27 PM
MixturePinoy's Avatar
your throttle body is still the same size though, you are going to see minuscule gains if any. Not just that, but you would also have to upgrade your internals, ecu, injectors, etc. for the extra air it is recieving. this mod is a FAIL
