Need help did my oil change and all only 2 1/2 qts came out
Old Apr 23, 2009 | 10:08 PM
0MGHI2U's Avatar
i have a 2006 g35 coupe 6mt.. and lately i been realizing that i have been only getting 2 1/2 qts of used motor oil coming out when i drain it. is this normal? i change my oil every 3,000-3,500 miles.. i use synthetic..
i have about 73,000 miles on my car.. f*#%King warranty is over..
Old Apr 23, 2009 | 10:20 PM
MikeGrote's Avatar
are you removing the oil filter too? is the car level?
im guessing you engine is using oil, search "oil consumption" on here this forum
Old Apr 23, 2009 | 10:24 PM
KSWAY's Avatar
If your engine is going through that much oil between oil changes. Then more likely you got the OC.
Old Apr 23, 2009 | 10:25 PM
0MGHI2U's Avatar
yea removed oil filter.. nd car level
Old Apr 23, 2009 | 10:26 PM
0MGHI2U's Avatar
but wiyh 73,000miles passed warranty you think they will fix it if my car is havin oc problems...imma call the corp screw dealer pa infiniti all suck
Old Apr 23, 2009 | 10:40 PM
jibberjabbers's Avatar
You are burning oil. You have an 06 and out of warranty? We need to make Infiniti recall all the 05-06 Rev-up motors.
As for the oil filter comments, I doubt an oil filter even holds 1/3 of a qt.
The G holds 5qts. And ohe nly got half back.
He should have at least gotten 4qts out. The G is burning oil. I wouldn't use Synthetic Oil from now on. Use the thicker dyno oil. Of, if using synthetic, use the 10w until you get a new motor.
Old Apr 23, 2009 | 11:16 PM
MikeGrote's Avatar
i was just brainstorming with the oil filter idea. but if youve ever noticed, more oil will come out of the drain plug when you take the filter off.
Old Apr 23, 2009 | 11:36 PM
teamspink20's Avatar
isnt that because there is more air flow with the filter off and drain plug out? i think you are seeing it come out faster there isnt necessarily more oil coming out
Old Apr 24, 2009 | 12:41 AM
MikeGrote's Avatar
it was on a different car when i saw it. i let it drain till it was a slow drip, then removed the oil filter, the slow drip changed to a slow pour. it wasnt a lot, but some extra did drain out. i would assume most cars would do this, prob just another part of the engine getting air like you said
Old Apr 24, 2009 | 01:10 AM
I"m assuming when he changed his oil, he also removed the oil filter. LOL
Old Apr 24, 2009 | 01:18 AM
MikeGrote's Avatar
you would be surprised, some ppl dont. he obviously didnt notice his engine only had half of the oil it should have....
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
