Twin SUPERCHARGED g35
#121
ive thought about this... wondered how it would work. are you running the vortech output into the stillen input? whats your routing?
#122
yea...i just did a bump start to make sure the belts were tracking and it accidentally started...ran like **** cuz i have no hoses or any lines hooked up and the mass airflow wasnt hooked up either but other than that it sounded normal
#123
What am I talking about?? "Forged internal engine components and a reversion from aluminum to a cast iron block help ensure the bottom end can handle the boosted power." That's what I'm talking about...your car has none of this that's why it should be interesting. I guess Ford lied to me.....
#125
You're telling me with a little boost a Cobra's 4.6 will go boom? ROFL!
#126
A stock 03-04 cobra is pushing 8-10 psi, and up to 17psi w/ no other supporting mods besides a tune and pulley or aftermarket s/c to get the boost up... as far as handling boost levels in stock setup the VQ is not even in the same league..
#131
what a sick fx35 in that pick.....ive seen that avatar before...anyways how should are you familiar with both kits..reason i aks is both have there own computer to hook up should i just hook both up i mean one is a tuneable one and the other just seems tho wire up and go from there with the added injector...i have a 255 inline but ive heard that i need an intank to actually keep up. and im not sure if i want to buy injectors yet because i dont want to buy something to small b/c i eventually want around 750whp and plus i was told that i cant just get large sized ones that i need to stay around current hp so i want to make sure i only make one purchase of a set. i mean injectors are gunna run 800+ b/c the damn rail has to be up graded to compensate for the bigger injectors and might as well upgrade the lines while your at it
Also, listen to Rookie. He DOES know what he is talking about.
