HR Short Block
^ Reasons? I say yes. If the head gaskets for the HR can be used on a Revup, that tells me that all the cooling and lubricant journals between the head and the block match perfect.
Pretty sure that will work. I don't think the design of the shortblock changed much, if at all. I think it just has beefier parts.
Exactly why do you think a 3.5hr block is going to make more power than a VQ35 block. You also have to consider how the valvetrain is driven (ie.. if it's the same inbetween the motors). Also the HP isn't made in the block. HP capacity might be built into the block but HP isn't. That's in the head/cam/valvetrain/intake/exhaust design along with the ecu controlling all of it.
Ya it might fit, but how well will it actually work? Is it worth risking total failure with all the money you're going to put into it parts and labor wise? How about sensors and ECU? I mean seriously why stop at the heads when you're that far into it.
Learned Hand
Oct 1, 2015 09:02 AM
I need to know if the HR block will match up with revup heads?
