How to spot a rev up engine *PICS*
Old Jun 30, 2013 | 04:25 PM
  #31
carl576's Avatar
Originally Posted by jwrape
Also the Rev up motor has the Green and Blue sensors on the front as well
That's how I figured out the block I was buying was the correct one.
My mechic states I must replace the green sensor illustrated in this picture. Do you know the name or part number. Ive been searching all night.
Old Jul 2, 2013 | 06:44 AM
  #32
jwrape's Avatar
Sorry I don't. I've just referenced them as the Self adjusting Timing sensors.
Old Jul 2, 2013 | 08:50 AM
  #33
LoSt180's Avatar
Good info in the first post, should help people getting replacement engines without access to the original car do compare dashes/trim/whatever.
Took me about 10 minutes, that is called a "Magnet Retarder" or "EXHAUST VALVE TIMING CONTROL MAGNET RETARDER" Looking in the FSM, it appears to be built into the valve timing control covers.
Edit, checked another parts site:
If you went to parts dept, it would be called: "CAM SPROCKET COVER & PULLEY KIT VTC" or "VTC COVER & PULLEY KIT"
Replacement part numbers are:
A3040-AC71A (RH)
A3040-AC71B (LH)
Old Jul 2, 2013 | 09:44 AM
  #34
jwrape's Avatar
A3040-AC71A (RH)
A3040-AC71B (LH)
^^^ That's good info to keep^^^^
Old Jul 5, 2013 | 02:33 PM
  #35
carl576's Avatar
Lost180. 10 minites how about ive been searching for a week, let alone the 2 infiniti and 3 nissan dealerships ive called. Tks man..seriously
Old Apr 26, 2014 | 04:18 PM
  #36
Nawar Alobaidi's Avatar
Hi,
i got a problem on my 2006 G35 coupe unstable engine and the code shown p0024 & p0084, but when i remove the blue plug which you circled in red the car gone smooth again looks like no problem on it.
any body know what is the solution or what is the problem.
other things what is that part effect?
Thank you
Nawar
Old Apr 26, 2014 | 09:38 PM
  #37
Lartytiejdke3's Avatar
Holy wrong thread
Old Oct 23, 2014 | 04:34 AM
  #38
Exodus5656's Avatar
Originally Posted by Calvin
For guys that don't know much about cars, I think it's easier for them to distinguish revups vs. non-revups by transmission and year....
All 5ATs - non-revup
03-04 6MTs - non-revup
05-07 6MTs - revup
I used the tranny/year for awhile, but never knew the big differences. I didn't see the little things. I know enough about cars to work on them, but I assumed it was all in the tune.
Old Feb 29, 2016 | 04:41 AM
  #39
3RDWIN's Avatar
Originally Posted by 350z006
What is an uprev engine??
UPREV : Software for tuning VQ engines
REVUP : Updated version of the VQ35DE
UPREV is not REVUP....
So question is the revup still a vq35de or is it the vq35hr? I've been confused about that.
Old Feb 29, 2016 | 04:43 AM
  #40
Originally Posted by 3RDWIN
So question is the revup still a vq35de...YES... or is it the vq35hr....I WISH
Answered
Old Feb 29, 2016 | 04:46 AM
  #41
3RDWIN's Avatar
Answered
Thanks! And now that I know that what is the difference between the de and the hr? Just trying to gain more knowledge here lol
Old Jan 7, 2017 | 09:14 PM
  #42
ignvciog35's Avatar
I have an 06 coupe revup
Old Jul 17, 2022 | 02:51 AM
  #43
G35Ismael's Avatar
It's a stock vq35de rev up I'm trynna find a rebuild kit for it
Does anyone know where I can buy a rebuild kit for a 2005 G35 rev up engine I been looking but can't seem to find any for the rev up engines a little help I new to these vq platform
Old Jul 17, 2022 | 10:54 AM
  #44
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You can buy the complete gasket kit from your local Nissan, same with the timing chain kit, water pump, oil pump. Piston/rods/bearings there's a ton of options.
Or you can buy a complete kit from a G/Z vendor like Concept Z Performance or Z1 Motorsports.
Old Jan 20, 2024 | 07:50 AM
  #45
QX1's Avatar
QX1
Originally Posted by T3K_V35
Ok guys....after doing my research and alot of looking, I finally had the chance to view these two cars sitting next to each other. And i got pics this time to prove it.
The Rev up motor with 298hp has variable cam timing on the exhaust side as well as the intake side. The non-rev up motor with 280hp only has it on the intake side. So to put this to rest once and for all....here is the easiest way to tell.
it is kind odd, that nmvtis says my car is auto, but when i brought it, was 6mt. what is the issue? my car sure do revs until 7300rpm respectfully?
wonderizm
Sep 24, 2015 03:09 AM
baker2795
Sep 2, 2015 06:00 PM
derres
Aug 28, 2015 03:27 PM
fredthesnail
Aug 27, 2015 09:26 AM
leo38cheng
Aug 9, 2015 12:14 PM
