Does Motordyne Plenum Spacer 5/16 increase HP?
Old Aug 15, 2011 | 05:39 AM
  #76
MADtotheA's Avatar
Yup
Old Aug 15, 2011 | 09:31 AM
  #77
R10T_x's Avatar
Originally Posted by hamzafraj
does it matter that I live in chicago? reason Im asking is: it gets cold during winter, lots of snow but also quite hot during summer.
would iso thermal be okay vs copper?
either one u get will be fine but i would get the copper one just so i wouldnt have to worry about anything like turning the bypass on and off
Old Aug 15, 2011 | 11:07 AM
  #78
gary c's Avatar
I'll repeat it again cause it's probably been mentioned in all these pages, MotoDynes spacer ISO is the best bang for your $$! The spacer corrects a Nissan design flaw or maybe it had something to do with the hood closing....lmao Between the spacer and tune those are the two best ways to increase RWHP in a first gen NA VQ motor without a total rebuild. HFCs and a quality dual exhaust are a close second!
Gary
Old Mar 8, 2012 | 11:00 PM
  #79
muhtish's Avatar
looks like this will be my first power mod...once I get the $$$
Old Mar 8, 2012 | 11:20 PM
  #80
MADtotheA's Avatar
$200 on eBay for iso thermal. Can't beat that on here.
Old Mar 9, 2012 | 03:06 AM
  #81
sillyoldtayo's Avatar
Gary
gary has a way with words....old thread revival ftw!
Old Mar 9, 2012 | 01:12 PM
  #82
flyz's Avatar
This thread.....
03-04 6MT - Spacer only
03-07 5AT - Spacer only
05-07 6MT - Spacer + MREV2
Basic will work
ISO will work better in warmer climates
ISO copper will work better in colder climates
5/16" for low-medium rpm power
1/2" for medium-high rpm power
How did this thread get 80+ posts?
Old Mar 9, 2012 | 01:41 PM
  #83
Jairen's Avatar
I got mine locally for cheaper at Riverside Infiniti for under $200.
Old Mar 9, 2012 | 01:45 PM
  #84
MADtotheA's Avatar
Cool story! Nah jk. Most people don't live by riverside infiniti though. I got mine for $199 free shipping on eBay. That's an iso thermal too. Not bad
Old Mar 9, 2012 | 02:33 PM
  #85
DrkBLuG35Sdn's Avatar
Originally Posted by flyz
This thread.....
Basic will work
Not trying to be difficult but I understand that the ISO will be better in places like arizona, and the copper will be better in places like canada, however for temperate climates that around around 55-75 degrees, which would be better or is there no real difference?
Old Mar 9, 2012 | 02:53 PM
  #86
herrschaft's Avatar
Was quoted for $190 several months ago by one of the vendors on here.
Old Mar 9, 2012 | 02:54 PM
  #87
gary c's Avatar
This thread.....
Basic will work
How did this thread get 80+ posts? Because members want to know!
I've been running the 1/2" spacer ISO with copper because I wanted to restrict the heat coming for the block which the copper does. Living in a warm climate I've kept the by pass hose closed since I installed it with no issues. This was my second mod back in '05 and one of my best decisions....Gary
Old Mar 9, 2012 | 07:59 PM
  #88
muhtish's Avatar
is that the MD iso thermal on ebay? or some knock off brand
Old Mar 10, 2012 | 09:33 AM
  #89
MADtotheA's Avatar
OC Infiniti sells them on eBay. It's legit.
Old Mar 11, 2012 | 10:39 PM
  #90
LoSt180's Avatar
Think of the copper as a "set it and forget it" part. The ISO comes with a valve that you splice in that shuts off coolant to the upper plenum / throttle body. When it's warm, you shut this valve (cutting off flow) keeping the whole plenum thermally isolated. When it's cold out, you open the valve (allowing flow) which keeps the throttle body from freezing. Basically coolant flow is a little heater.
The Copper replaces this valve. Coolant always flows, but instead of going into the upper plenum, it warms a plate on the throttle body directly. With the copper, you don't have to remember open the valve when the weather gets cold... set it and forget it.
