Fuel cuts 3000rpm SLIP and VDC OFF come on
Old Jul 14, 2010 | 06:30 PM
iggut's Avatar
Hi,
I just started having this problem. Almost every time I get to 3000 rpm the slip and vdc off lights come on and it cuts the fuel as if hitting a governor. Turning the car off and on again fixes it and I can rev past 3000 again.
Can someone please point me in the right direction?
6mt 04 , new air filter, premium gas and oil change just performed.
Old Jul 15, 2010 | 01:21 PM
HotRodG35's Avatar
Check for computer codes. Thier maybe an issue with Throttle body position sensor.
Thier very sensitive because of the Drive By Wire throttle control.
Old Jul 15, 2010 | 01:45 PM
Deezflip's Avatar
+1 on the throttle body, and i would check the air intake part of the engine. Was the new air filter prep and oiled? too much oil maybe and got some on the maf sensor.
Old Jul 16, 2010 | 08:53 PM
iggut's Avatar
K&N filter seams oiled from factory so it was installed as is.
Will check codes and throttle body. Thanks
Old Jul 16, 2010 | 09:04 PM
rpm06g35's Avatar
Just went through this and it will only get worse and leave you stranded. Its either the gas peddle sensor of the throttle body sensor. let me know if you need some advice mike
ps search limp mode on my350z.com
Old Jul 16, 2010 | 09:23 PM
iggut's Avatar
Know of a quick way to check the 2? Not familiar with the procedure.
Old Jul 16, 2010 | 11:38 PM
T3K_V35's Avatar
03' track... Soon to be race car.
Yeah, you need someone with access to a nissan consult 2 or 3 to pull the codes. Generic scanners will get data from the engine, but not if the problem is elsewhere. Is it setting a check engine light?
Old Jul 17, 2010 | 02:17 AM
iggut's Avatar
Nop, no check engine light comes on. Only the VDC OFF and Slip stay on when it happens and disappear when the car is restarted. Seems to happen a lot less when the car has been running for more than 30 min.
I will try finding someone with one of those tool to help me pull the code.
Old Jul 18, 2010 | 05:01 AM
oneup's Avatar
Had this happened to me few years back, MAF sensor was to blame for in my situation.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
markbilo
Sep 30, 2015 01:33 AM
Hogbone
Sep 28, 2015 06:44 PM
vamarris
Sep 26, 2015 12:56 PM
