DIY Cam Position Sensor Easy Version
Rating: Thread Rating: 6 votes, 5.00 average.
Old May 30, 2011 | 07:38 PM
  #31
jin22gt's Avatar
Is it normal for the old sensors to have oil on them???
Old May 30, 2011 | 07:46 PM
  #32
JaE35's Avatar
Moderator
G35 Sedan
that's a great question, i assume so. Mine was soaked
Old May 30, 2011 | 07:57 PM
  #33
jin22gt's Avatar
Originally Posted by JaE35
"No products match your search criteria, please try again."
that is why lol
You gotta call them and ask for the part. The parts are nissan parts and much cheaper then dealership...
Old May 30, 2011 | 08:30 PM
  #34
JaE35's Avatar
Moderator
G35 Sedan
good to know, i was in a must have immediately situation
Old May 30, 2011 | 11:43 PM
  #35
jin22gt's Avatar
Report;
I replaced both sensors, had the code "po340".
No need to take off the intake to replace the sensor on the driver side. U just go to the passenger side and stick ur arm in behind the engine. I had to feel my way around, feel/look for a harness with a 10m bolt.
The hardest part for me was taking the freaking harness off!
I disconnected my battery to reset the ecu.
So far I got 20 miles and no cel! Car feels faster and more responsive, but it might be all up in the head.
Its an easy fix if u got the time, and u could save some money.
Old Jun 2, 2011 | 02:47 PM
  #36
TwoFiveBravo's Avatar
Just like I said having oil on it is normal also.
Old Jun 7, 2011 | 07:11 PM
  #37
Azhreal's Avatar
I have an 06 G35 Sedan and am trying to replace the passenger sensor and they have added a long metal rod that runs vertically behind the hose so that you cannot go directly at the bolt. Does anyone have any idea how to get to the bolt on an 06?! This is driving me insane.
Old Jun 7, 2011 | 07:18 PM
  #38
Blue Dream's Avatar
I drove ttrank's car solo
Would a ratcheting socket wrench work? It's got a low profile and would just slip over the bolt head.
Old Jun 7, 2011 | 07:19 PM
  #39
Blue Dream's Avatar
that is why lol
Ahh gotcha.
Old Jun 7, 2011 | 07:21 PM
  #40
JaE35's Avatar
Moderator
G35 Sedan
Weird, get a good pic of it and post it
Old Jun 7, 2011 | 07:24 PM
  #41
Azhreal's Avatar
Attached. I dont have anything short enough to hit it in front of the hose.
Old Jun 7, 2011 | 07:30 PM
  #42
JaE35's Avatar
Moderator
G35 Sedan
Lame i see what your saying, can you not reach it at all with an extension? Looks like you may have to get to it with a shorter socket
Old Jun 7, 2011 | 07:35 PM
  #43
Azhreal's Avatar
It would have to be one hell of a NEEDLE like 3 inch extension, or a socket that fits directly onto the wrench. That's my last effort without taking the hose out, but I'll have to hunt down a 10mm or 3/8 large open socket or a small fitting wrench to put the socket onto. Damnit. This thread is great info though... maybe add this image and possible issues to it for the 06 G35 sedan. It's as if they did this on purpose to **** us off, lol.
Old Jun 8, 2011 | 12:29 AM
  #44
jin22gt's Avatar
That bolt is hard to get to. I lossen it up with a 3' extension 10mm socket. You have to come in with a slight angle. I also pushed the plastic wire cylinder slightly out of the way with my hand. When the bolt gets loose, just use your fingers to remove the bolt.
I couldnt find a 10mm wrench, so I used the extension w/ 10mm socket. But if you have a 10mm wrench, try using it. It should be much easier and might reach.
Good luck on trying to remove the green harness thats connected to the sensor. Had alot of problem trying to remove the harness.
Old Jun 8, 2011 | 07:36 PM
  #45
Azhreal's Avatar
Any tips on that? Push in or down, any clips? It looks brutal and won't budge.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
