DIY Cam Position Sensor Easy Version
Rating: Thread Rating: 6 votes, 5.00 average.
Old Jan 30, 2021 | 08:17 PM
  #421
Bongizzle's Avatar
G35 sedan
Just to verify try changing the range on your meter, try 200 and 2k if you have it.
Yup I started with 200 then moved up to 2k then 200k even 2M
Old Aug 17, 2021 | 02:42 PM
  #422
keithloomis's Avatar
Doing this now. Camshaft sensor bank 1. Will report back how it goes
Old Aug 17, 2021 | 07:24 PM
  #423
Apparition's Avatar
Do both sides, & it wouldn't hurt to do the Crankshaft Position Sensor while you're at it. It's even easier to do. Just have to get under the car.
Old Aug 20, 2021 | 12:05 PM
  #424
Apparition - I decided to just do the passenger side as this is what the code was for. Just gonna hold off on others.
Car has been running great since new cam sensor installed. I picked it up from my local infiniti. I originally went to a Nissan but they would not warranty the part so I decided to go to infiniti.
One thing to note is this part number now ends in "D". The new sensor looks a lot different then the old one. Old one is all black and plastic like the ones everyone is posting in pictures. For the new one the part that goes into the motor is a shiny metal cylinder.
Old Jul 19, 2022 | 03:26 AM
  #425
JennJenn2121's Avatar
350Z & G35 Coupe
Originally Posted by The_Silencer
Thank you SO MUCH! It was a cinch to remove the clip once the bolt was removed. Otherwise it would've been impossible for me to change the passenger side sensor by trying to remove the clip first. Unfortunately, I ran into more issues. After I replace all 3 sensors, the car refused to start at all! After much tinkering, it turned out that the passenger side sensor was preventing the car from starting. I replaced it with the OEM one and it finally started up. THe 2 other sensors I bought from Rock auto are still in place. However, the SEL, SLIP, and NO VDC light are on. Though it starts up now, its takes a good 3-4 or so seconds of cranking to start. My car used to start instantly before the sensor swap Is all this trouble caused by using non NIssan parts?
YES! These cars are finicky bitches when it comes to sensors they will only function properly with OEM, save yourself the trouble and buy OEM out the gate,
DGrantG
Apr 23, 2019 08:48 PM
LowUFO
Apr 5, 2011 12:37 AM
masterdave
Jul 13, 2010 03:53 PM
sliderg35
Forced Induction
Jan 12, 2008 08:53 PM
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
