problem with kinetix v4 plenum
Old Dec 6, 2004 | 12:23 AM
panda007's Avatar
Hi. i just installed the kinetix v4 plenum and test drove the car. car cranked up fine like stock and i took it for a wild spin to test it out. came back home and told my friend to test it out hours later... cranked the car, rpm fell down to 0 and the car stalled. cranked again, same deal... so i cranked it with some gas and the car fell to a very smooth idle. turned it off and cranked it again with a long start and the car fell to a very smooth idle. i then proceeded to drive the car for 30 minutes and turned off the car in attempt to see if the car will crank up normally... but it doesn't!
anyone have a clue what i am talking about? idles and rpms are very smooth and nominal though.. no bogging while riding! only during crank/ignition... seems like car is not getting enough combustion to start?
Old Dec 6, 2004 | 05:33 PM
jjellyneck's Avatar
Is the car still doing this after some driving?
Also, did you happen to notice more power with the plenum?
I'm not yet sure what the cause might be. Cranking the car over while applying throttle is a technique for starting a flooded (with gas) engine.
Old Dec 6, 2004 | 08:53 PM
panda007's Avatar
thanks for the reply!
only happens during hot-cranks... during cold-cranks the car ignites with ease at a higher idle. yes i THINK i noticed a bit more power at top end.
i apply the gas only when the revs start to drop to induce a stall. need more air to keep the engine alive.
i guess i shall disassemble the plenum and parts tomorrow... get everything thoroughly checked... we'll see what the culprit was.
Old Dec 6, 2004 | 09:05 PM
willthethrill's Avatar
did you try just doing an ecu reset after the install..who knows it may work.
Old Dec 6, 2004 | 09:51 PM
jjellyneck's Avatar
You might want to try the idle reset. I believe that the steps to do that are on the DIY section of this forum.
Old Dec 7, 2004 | 12:23 AM
Hydrazine's Avatar
Sounds like you may have an air leak.
Julianpnce
Intake & Exhaust
Sep 1, 2015 07:41 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
G35_TX
59
Jul 8, 2004 03:24 AM
Dsskyline
Tuner & Dyno
Apr 17, 2004 08:58 PM
brnSkyline
Intake & Exhaust
12
Apr 12, 2004 11:56 PM
